Restore Options (General) - Online Help
Use this dialog box to control how the specified data is to be restored. This dialog box is also used for selecting options related to scheduled or non-scheduled search and restore operations.
Restore ACLs
Specifies that the backed up Access Control Lists (ACLs) will be restored. Files will inherit the ACLs from the parent or an ancestor directory if the parent or the ancestor directory is configured to set the ACLs recursively for the directories below it. Clear this option to restore without ACLs.
Data in device node
Specifies if data in the raw device nodes is to be restored.
Unconditionally overwrite only if target is a DataArchiver stub
Specifies whether a stub will be unconditionally overwritten during restore.
Overwrite
Overwrite if file in backup is newer
If selected, this option will overwrite the existing file with the file that was backed up/archived to the media provided the backed up/archived file is newer than the existing file.
Unconditional Overwrite
Specifies whether the restored data is unconditionally written to the specified location.
Restore only if target exists
If selected, this option will only restore files that currently exist in the restore path. Files that exist on the media but not in the restore path will not be restored.
Restore data instead of stub
If selected, data will be restored instead of stubs.
Restore Destination
UNIX File System
Specifies if you want to use a regular file system data restore framework.
Big Data Apps
Specifies if you want to use a big data file system data restore framework.
Destination Client (Applies to UNIX File System)
Displays the name of the client computer to which the selected data will be restored. To change the destination computer, select one from the list. The list includes clients:
  • Which are established as clients within the CommCell.
  • Clients with Operating Systems that support the cross-platform restore operation from this client. (Refer to the topic titled Cross-Platform Restore Operations in Books Online for additional information.)
Destination Client (Applies to Big Data Apps)
Displays the name of the pseudo-clients to which the selected data will be restored. To change the destination pseudo-client, select one from the list.
Destination Instance (Applies to Big Data Apps)
Displays the name of the big data application instance to which the selected data will be restored. To change the destination instance, select one from the list.
Restore to Same Folder
Select this option to restore in the same folder where the data already exists. If this option is selected you will be unable to specify any other destination path.
Specify Destination Path
This option is available when the destination client is not the same as the host client. Click Browse to select a path for the destination folder. Alternatively, you may enter the path.
Preserve Source Paths
Specifies the action taken when the data is restored to another destination. The options are available only when the Restore to same folder option is cleared.
Preserve n levels from end of the source path
Specifies whether the restore operation must keep the specified number of levels at the end of source path of the selected data. For example, if the selected data is documents/memos/sales, this option is set to 1 and the destination folder is temp, the data will be recovered as /temp/sales.
Remove n levels from beginning of the source path
Specifies whether the restore operation must remove the specified number of levels from the beginning of source path of the selected data. For example, if the selected data is documents/memos/sales, this option is set to 1 and the destination folder is /temp, the data will be recovered as /temp/memos/sales.
Impersonate User
Select this option to restore files as the impersonated user. For out-of-place restores, the user must have the necessary privileges to write to the destination directory.
User Name
In this box, type the user name.
Password
In this box, specify the password for the user account.
Confirm Password
In this box, confirm the password for the user account.
Advanced
Click to select additional restore options.
Save As Script
Click to open the Save As Script dialog, which allows you to save this operation and the selected options as a script file (in XML format). The script can later be executed from the Command Line Interface using qoperation execute command.
When you save an operation as a script, each option in the dialog will have a corresponding XML parameter in the script file. When executing the script, you can modify the value for any of these XML parameters.
