System Requirements for the Cisco HyperFlex Storage Array
Before you configure the storage array, verify that your environment meets the system requirements.
Licenses
Install the following licenses.
Snapshot type
Licenses
Snapshot
None
Version and Firmware
Use the following version and firmware.
Array
Version and firmware
Cisco HyperFlex
  • HXDP 3.0.1e
  • HXDP 3.5.2a
  • HXDP 4.0.1b
  • HXDP 4.0.2a
  • HXDP 4.5.1a
  • HXDP 4.5.2a
  • HXDP 5.0.1b
  • HXDP 5.0.2g
Check if the Cisco HyperFlex version, the VMware ESXi version, and the VMware vCenter version are compatible. For information about compatibility with the VMware software, go to the "Software Requirements for VMware ESXi" on the Cisco website.
Protocols
Use one of the following protocols.
Array
Protocols
Cisco HyperFlex
NFS 3
Software
  • In the guest VM, install the most recent VM tool.
  • You do not need to install any software in the storage array.
Ports
For snapshot backup operations from the Commvault software, open port 443 between server computers, MediaAgents, and client computers.
