System Requirements for the Oracle ZFS Storage Array
Deprecated
This engine is deprecated from the Commvault software in Commvault Platform Release 2023 (11.30).
See End-of-Life, Deprecated and Extended Support - Features for information about deprecated features.
Before you configure your storage array, verify that your environment meets the following requirements.
Licenses
Install the following licenses.
Snapshot Type
License
Snapshot
Separate cloning license per controller or node
Version and Firmware
Use the following version and firmware.
Array
Oracle ZFS
  • Oracle ZFS Engine supports both ZS3-2 and ZS3-4 with the minimum firmware versions required for these appliances.
  • For earlier versions of the Oracle ZFS, use versions:
    • For environments not using VMware agents, use 2013.1.0.1
    • For environments not using VMware agents, use 2011.1.4.2
More information on updates can be found in the Oracle Wikis Home - Software Updates.
Protocols
Use one of the following protocols.
Array
Protocol
Oracle ZFS
  • Fibre Channel
  • iSCSI
Software
Install the following software.
Array
Required Software
Oracle ZFS
None
Support for Agents
The support for agents is deprecated. Review the following specific considerations:
  • Oracle ZFS for VSA with Linux Proxy is not supported.
  • Oracle ZFS for VSA with Windows Proxy is deprecated.
Ports
You do not need to open any specific port.
