System Requirements for the Silk Storage Array
Before you configure your storage array, verify that your environment meets the following requirements.
Licenses
Install the following licenses.
Snapshot Type
License
Silk Snap
None
Version and Firmware
Use the following versions and firmware.
Array
Silk
  • 5.8.4.14
  • 6.0.60.56
Protocols
Use one of the following protocols.
Important
For iSCSI LUNs, configure the host in the same subnet of the storage array.
Array
Protocol
Silk
  • Fibre Channel
  • iSCSI
Software
Install the following software components:
Array
Required Software
Silk
None
Ports
You do not need to open any specific port.
