Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses:
Snapshot Type |
License |
Tintri VMstore Snap |
None |
Version and Firmware
Ensure that you are using compatible versions and firmware:
Array |
Version and Firmware |
Tintri VMstore |
4.3.2.4-9170.48932.21603 4.6.2.1-11182.55325.24595 REST API version v310 |
Protocols
Ensure that at least one of the following protocols is available:
Array |
Protocol |
Tintri VMstore |
NFS 3.0 |
Software
Install the following software components:
Array |
Required Software |
Tintri VMstore |
None |
