From backups performed with the Virtual Server Agent, you can perform a full VM restore and convert the source virtual machine to be used with a different hypervisor.
You can perform conversions from streaming backups, from secondary copies, or, for hypervisors that support IntelliSnap, from IntelliSnap backup copies. You can--t perform a conversion from a Snap copy.
The following table shows the cross-hypervisor restores that are supported by Commvault.
DESTINATION |
Alibaba Cloud ECS |
Amazon EC2 |
Azure |
Azure Stack Hub |
Azure Stack HCI |
Google Cloud Platform |
Hyper-V |
Nutanix AHV |
OpenStack |
Oracle VM |
Oracle Cloud Infrastructure |
Red Hat Virtualization |
VMware |
SOURCE |
Amazon EC2 |
Yes |
Yes |
Yes |
Azure |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Azure Stack Hub |
Yes |
Azure Stack HCI |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Hyper-V |
Yes |
Yes |
Yes |
Yes |
Yes |
Nutanix AHV |
Yes |
Yes |
Oracle VM |
Yes |
Yes |
VMware |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
