Checking for Data Transferred After the Total Running Time Expires
This additional setting applies to backup jobs. Use the JMMaximumAllowedTimeWithoutDataTransfer additional setting to run a backup job past the total running time if the backup job has transferred data within the last n minutes of the total running time. For instruction on setting the total running time, see Setting the Total Running Time.
Example
  • Total running time equals 2 hours
  • JMMaximumAllowedTimeWithoutDataTransfer equals 30 minutes
A backup job starts at 9 a.m. At 11 a.m. the backup job is not complete, so it has exceeded the total running time of 2 hours. The last 30 minutes of the total running time is checked: 10:30 a.m. to 11 a.m. If data was transferred between 10:30 a.m. to 11 a.m., the backup job continues to run. If no data was transferred, the backup job is killed.
  1. From the CommCell Browser, navigate to CommServe.
  2. Right-click CommServe, and then click Properties.
  3. In the CommCell Properties dialog box, click the Additional Settings tab and then click Add.
    The Add Additional Settings dialog box is displayed.
  4. In the Name field, type JMMaximumAllowedTimeWithoutDataTransfer.
  5. In the Category box, select CommServe.
  6. In the Type box, select INTEGER.
  7. In the Value box, type the number of minutes, for example, 45.
  8. Click OK.
