The GxTail toolbar provides quick access to the following functions:
The following tools are not self-descriptive:
Open one or more files into individual tabs
Open one or more log files. If you select more than one, each opens in its own tab.
Open multiple files into one merged tab
Open many files, sequenced by time stamp, in one new tab named mergeOutput.log.
Toggle Tail
When this option is cleared for a window (as indicated by this icon:
), the view in that window does not automatically scroll to the bottom of the file each time a new message is added to the log file. Messages do continue to accumulate at the bottom of the window, if they are being appended to the log file.
Work Offline
Set this option to prevent the currently active file from being dynamically updated while you are looking at it. Applies only to files that can be dynamically updated.
Edit Multiple Markers
Click to open the Markers & Filter dialog box for setting high-level marker and filter parameters. For more information, see "Markers and Filter" in Help for GxTail Dialog Boxes.
Copy Marker from selected tab to tabs like this
Click to copy marker settings from the current tab to all the other open tabs that match this file type. Note that file type is determined by the file name, not extension.
Copy Marker from selected tab to all tabs
Click to copy marker settings from the current tab to all the other open tabs.
Filter
Click to open the Filter Properties dialog box. See Filtering Log Messages by Text.
Filter folders based on profile marker values
Click to open the Profile based Filter dialog. See Filtering Log Messages by Text > Read Filter Criteria from Saved Profiles.
