Subclient Properties (Advanced Options) - Online Help
Use this tab to manage the advanced options of a selected subclient.
Reconcile Backup
Select the option to enable the synchronization of data on the source disk and the index. After you enable this option, the subsequent backup job compares the subclient content on the disk to the data on the index, and identifies the files that are missing from the subclient content on the disk and the index. The missing files are then included in the backup job. A scenario that might result in the discrepancy is a cut and paste operation on a file that does not change the modified time of the file. As a result, when you use the recursive scan method, the file is not selected during the backup operation.
Every n days from the previous backup job
Enter the number of days after which any backup job will run the synchronization job. By default, the synchronization runs after every incremental job that runs after a synthetic full backup.
Catalog additional file and system attributes
Enable collection of file and system data so you can create a report with the Build-Your-Own Reports feature or run the File Level Analytics Reports.
Exclude from SLA and Strike Counts
When this option is selected, the subclient is excluded from the SLA (Service Level Agreement) calculation and the Client Strike calculation for the Worldwide Dashboard, CommCell Dashboard, SLA Report, and Client Strike Count Report. When this option is cleared, the subclient is included in these calculations.
Ignore Strikes Before
When selected, allows you to configure the cutoff date for counting strikes. Any strikes that occurred prior to the date you specify will not be counted in the strike calculation for the Worldwide Dashboard, CommCell Dashboard, and Strike Count report.
