Deprecated
This engine is deprecated from the Commvault software in Commvault Platform Release 2023 (11.30).
See End-of-Life, Deprecated and Extended Support - Features for information about deprecated features.
Before you configure your storage array, verify that your environment meets the following requirements.
Licenses
Install the following licenses.
Snapshot Type |
License |
Snapshot |
Separate cloning license per controller or node |
Version and Firmware
Use the following version and firmware.
Array |
Version and Firmware |
Oracle ZFS |
More information on updates can be found in the Oracle Wikis Home - Software Updates.
Protocols
Use one of the following protocols.
Array |
Protocol |
Oracle ZFS |
Software
Install the following software.
Array |
Required Software |
Oracle ZFS |
None |
Support for Agents
The support for agents is deprecated. Review the following specific considerations:
Oracle ZFS for VSA with Linux Proxy is not supported.
Oracle ZFS for VSA with Windows Proxy is deprecated.
Ports
You do not need to open any specific port.
