Unattended Installation Using a Custom Package on UNIX Client
You can configure a direct connection from the client to the CommServe computer during an unattended installation using a custom package on a UNIX client.
  • From the command prompt on the UNIX client, run the following command:
    ./silent_install -fwtype 0 -csclientname CS clientname -cshost CS hostname -tunnelport tunnelport -httpproxyhost httpProxyHostName -httpproxyport httpProxyPortNum -authcode authcode
    Where:
    • fwtype 0 means that this client can open a tunnel to the CommServe client (required)
    • <CS clientname> is the CommServe client name (optional)
    • <CS hostname> is the CommServe hostname (optional)
    • <tunnelport> is the tunnel port of the CommServe client (optional)
    • <httpProxyHostName> is the hostname of the proxy (optional)
    • <httpProxyPortNum> is the port number of the proxy (optional)
    • <authcode> is the authcode of the CommCell or company (optional)
      If you run the command without optional parameters, the installation procedure will use recorded information from the custom package.
