Unattended Installation Using a Custom Package on UNIX Client
You can configure a direct connection from the CommServe computer to the client during an unattended installation using a custom package on a UNIX client.
You must create a placeholder for the client that will receive connections from the CommServe computer. Follow the appropriate instructions based on the type of network route configuration:
  • From the command prompt on the UNIX client, run the following command:
    ./silent_install -fwtype 1 -csclientname CS clientname -tunnelport tunnelport -authcode authcode -httpproxyhost httpProxyHostName -httpproxyport httpProxyPortNum
    Where:
    • fwtype 1 means that the CommServe client can open a tunnel to this client (required)
    • <CS clientname> is the CommServe client name (optional)
    • <tunnelport> is the tunnel port of the local client (optional)
    • <authcode> is the authcode of the CommCell or company (optional)
    • <httpProxyHostName> is the hostname of the proxy (optional)
    • <httpProxyPortNum> is the port number of the proxy (optional)
      If you run the command without optional parameters, the installation procedure will use recorded information from the custom package.
