SYSTEM CAPACITY (RAW)1 |
24 TB |
SYSTEM CAPACITY (USEABLE)2 |
14.5 TB |
HARD DISK DRIVE |
3 qty. - SAS, 12 GB/s, 8 TB, 7,200 rpm, 512 n, hot-plug, 3.5, configured with hardware RAID5 |
M.2-BASED FLASH STORAGE |
240 GB |
SATA SSD (DDB/INDEX CACHE) |
960GB |
MEMORY |
256 GB DDR4 |
COMPUTE |
2 x Intel Xeon Silver 4208 8C 2.10 GHz Total 16 Cores |
CHIPSET |
Intel® C622 |
ON-BOARD NETWORK CONNECTIVITY |
2 x 1/10 GbE BASE-T, and 2 x 10 GbE SFP+ |
OPTIONAL ADD-IN CARDS |
16 Gb/s Dual Port PCIe FC HBA 12 Gb/s SAS Dual Port PCIe HBA |
WEIGHT |
Up to 20.9 kg (up to 46 lbs) * It is recommended that the node be carried and racked by at least 2 people. |
DIMENSIONS |
1 rack unit 437 mm (body) x 650 mm x 43 mm 17.2” x 25.6” x 1.7” |
POWER SUPPLY |
2 x hot-plug power supply for redundancy per node 700 W hot-plug, 94% efficiency, 100-240 V, 50 / 60 Hz |
RATED VOLTAGE RANGE |
100 V to 240 V |
FREQUENCY |
50 Hz - 60 Hz |
MAX. RATED CURRENT |
8A / 6A |
MAIN POWER FUSE |
16A |
OPERATING AMBIENT TEMPERATURE |
10° to 35° C (50°- 95° F) |
OPERATING RELATIVE HUMIDITY |
8 - 90% (non-condensing) |
WARRANTY COVERAGE |
On-site hardware warranty – next business day |
SOFTWARE MAINTENANCE3 |
Premium software maintenance |
1 Raw capacity value calculated using Base10 (that is, 1 TB = 1,000,000,000,000 bytes) 2 Useable capacity value calculated using Base2 (i.e 1 TB = 1,099,511,627,776 bytes) 3 Software maintenance is based on subscription licensing and pricing
