You can monitor virtual machine protection from the Job Details dialog box or monitor an active or completed job. Based on the virtual machine status, you can suspend or re-submit jobs as required.
Skipped VMs will not cause a job to register as Completed With Errors (CWE).
A job will be marked as completed, when its content consists of completed VMs without any errors even if it contains some skipped VMs.
To view virtual machine backup status for a specific job, see Viewing Virtual Machine Backup Status.
Controlling Jobs
The following actions can be performed on Virtual Server Agent jobs:
Action |
Description |
You can control the actions of jobs running from the Job Controller tab. |
Jobs that fail to complete successfully are automatically restarted based on the Control Panel configuration on the Data > Job Management > Job Restarts tab. For Virtual Server Agent backups, select the job type File System and Indexing Based (Data Protection) (this setting also affects other agents). You can change the configuration at any time; however, changes to this configuration affect all jobs that run in the entire CommCell. |
You can override the default CommServe configuration for individual jobs by configuring retry settings when starting a job. This configuration applies only to that job. |
Use the Kill option when you want to interrupt eligible backup jobs that have exceeded their running time or are in a pending state, while preserving the data for restores. |
For streaming backups that use the Virtual Server Agent (VSA), if you try to stop a backup job that is eligible to be committed by using the Kill option, you are prompted to commit the job rather than to stop it.
When you suspend a job or a job changes to Pending state, the job removes snapshots for virtual machines that were being backed up. When the job resumes, the job takes new snapshots and backs up virtual machines that were in progress from the beginning.
When streaming backup jobs for the Virtual Server Agent are restarted or resumed, the job continues by backing up any virtual machines that have not yet been backed up and committed to backup storage, including any virtual machines that have been partially processed. (Virtual machines that were backed and committed to storage are not backed up again.) IntelliSnap backup jobs for the Virtual Server Agent are restarted or resumed from the beginning.
Failed Jobs
By default, a job fails if a VSA proxy cannot make a connection to the virtualization manager, or if an error occurs that prevents an operation from completing successfully (such as being unable to take a snapshot during a backup).
You can modify this behavior by configuring the following additional settings.
For instructions on adding additional settings from the CommCell Console, see Adding or Modifying Additional Settings from the CommCell Console.
To force a VSA backup job to Pending state if a connection to the virtualization manager cannot be established, add the bPendingOnVMInfoConnectFailure additional setting on the VSA proxy that is used for the operation.
Property
Value
Name
Category
VirtualServer
Type
Boolean
Value
true
To force a VSA backup job to Pending state if any failure occurs, add the bPendingOnAllFailures additional setting on the VSA proxy that is used for the operation.
Property
Value
Name
Category
VirtualServer
Type
Boolean
Value
true
