Verify that your environment meets the system requirements for the CommCell Console as a Stand-Alone Application.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Linux
If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
Operating system |
Processor architecture |
Debian 5.x and above |
Fedora release 8 and above |
Red Hat Enterprise Linux 7.0 and above |
SuSE Linux 10 Initial Release and above |
Ubuntu 8.04 |
OS X El Capitan (v10.11.x) |
All Macintosh-compatible processors supported |
OS X Yosemite (v10.10.x) |
Windows
Operating system |
Microsoft Windows Server 2022 Editions |
All Windows-compatible processors are supported |
Microsoft Windows Server 2019 Editions |
Microsoft Windows Server 2016 Editions |
Microsoft Windows Server 2012 R2 Editions |
Microsoft Windows Server 2012 Editions |
Microsoft Windows Client 10 Editions |
Microsoft Windows 8 Editions |
Microsoft Windows 7 x64 Editions |
Hard Drive
65 MB of disk space
763 MB of temp space required for install or upgrade (where the temp folder resides)
Display
The minimum resolution required to properly display the CommCell Console is 1280 x 1024.
The graphical icons in the CommCell Console cannot be displayed in VGA mode. This affects the appearance of the toolbar and the CommCell tree in the CommCell Browser. Also, some table of contents is not displayed correctly.
Other Requirements
IPv6
The CommCell Console supports Internet Protocol version 6 (IPv6). For more information, see IPv6 Requirements.
Service Pack Versions
The CommCell Console and the CommServe computer must have the same service pack version.
Java SE Platform
Java is installed automatically during the installation of this software. If you already have a system-installed Java version, the software installs another instance of the supported Java version in the software installation path.
All Commvault binaries (JAR files) are signed by SHA-256 Digest. To verify that the downloaded JAR files from Java webstart/netx.jar are not modified, use SHA 256.
Commvault always updates the Java version with the most recent security updates, so that the components using Java do not have any vulnerabilities that are reported by the open source community. To manually upgrade the Java Runtime Environment (JRE) for the Commvault software, see KB article 57019.
DISCLAIMER
