Before you configure the storage array, verify that your environment meets the system requirements.
Encryption Algorithm
The Commvault software uses libssh version 2-1.6.0 with the following algorithms:
hmac_sha1
hmac_md5
hmac_md5_96
hmac_ripemd160
hmac_ripemd160_openssh_com
Licenses
Install the following licenses.
Snapshot Type |
License |
Snapshot |
HyperSnap |
Clone |
Version and Firmware
Use the following version and firmware.
Array |
Version and Firmware |
Huawei OceanStor Convergent Series |
Huawei OceanStor Dorado Series |
Protocols
Use one of the following protocols.
Array |
Protocols |
Ports
Operations |
Port to Open |
Snapshot on vStores or on the physical array |
22 (SSH) and 8088, between the CommServe computer, client, Proxy MediaAgent and the Huawei storage array. |
