Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses:
Snapshot Type |
License |
Snapshot |
None |
Version and Firmware
Ensure that you are using compatible versions and firmware:
Array |
Version and Firmware |
Nutanix |
Microsoft Hyper-V hypervisor: AOS 5.20, 5.19, 5.17, 5.15, 5.11, 5.10.x, 5.9.x, 5.5.x, 5.1.x, 5.0, 4.7, 4.6.x, 4.5.x Nutanix AHV hypervisor: AOS 7.3.x, 7.0.x, 6.0, 5.20, 5.19, 5.18x, 5.17.x, 5.15, 5.11, 5.10.x, 5.9.x, 5.6.x, 5.5.x, 5.1.x, 5.0, 4.7, 4.6.x, 4.5.x VMware hypervisor: AOS 5.20, 5.19, 5.18x, 5.17.x, 5.15, 5.11, 5.10, 5.8.x, 5.9.x, 5.5.x, 5.1.x, 5.0, 4.7, 4.6.x, 4.6, 4.5.x |
Protocols
Ensure that at least one of the following protocols is available:
Array |
Protocol |
Nutanix |
Microsoft Hyper-V uses SMB3 VMware uses NFS |
Software
Install the following software components:
Array |
Required Software |
Nutanix |
None |
Ports
For snapshot backup operations from the Commvault software, open port 9440 between server computers, MediaAgents, and client computers.
