You can configure a direct connection from the client to the CommServe computer during an unattended installation using a custom package on a UNIX client.
From the command prompt on the UNIX client, run the following command:
./silent_install -fwtype 0 -csclientname CS clientname -cshost CS hostname -tunnelport tunnelport -httpproxyhost httpProxyHostName -httpproxyport httpProxyPortNum -authcode authcodeWhere:
fwtype 0means that this client can open a tunnel to the CommServe client (required) -
<CS clientname> is the CommServe client name (optional)
<CS hostname> is the CommServe hostname (optional)
<tunnelport> is the tunnel port of the CommServe client (optional)
<httpProxyHostName> is the hostname of the proxy (optional)
<httpProxyPortNum> is the port number of the proxy (optional)
<authcode> is the authcode of the CommCell or company (optional)
If you run the command without optional parameters, the installation procedure will use recorded information from the custom package.
