You can configure connectivity to the CommServe computer using a network gateway during an unattended installation using a custom package on a UNIX client.
From the command prompt on the UNIX client, run the following command:
./silent_install -fwtype 2 -csclientname CS clientname -tunnelport tunnelport -proxyhost proxyhostname -proxyclientname proxyclientname -httpproxyhost httpProxyHostName -httpproxyport httpProxyPortNum -authcode authcodeWhere:
fwtype 2means that the CommServe client is only reachable via a network gateway (required) -
<CS clientname> is the CommServe client name (optional)
<tunnelport> is the tunnel port of the proxy client (optional)
<proxyhostname> is the hostname of the proxy client (optional)
<proxyclientname> is the client name of the proxy client (optional)
<httpProxyHostName> is the hostname of the proxy (optional)
<httpProxyPortNum> is the port number of the proxy (optional)
<authcode> is the authcode of the CommCell or company (optional)
If you run the command without optional parameters, the installation procedure will use recorded information from the custom package.
