Use XML to create DB2 MultiNode pseudo clients. Run the operation from the command line, or automate configuration by combining command line operations in a script.
The XML parameters can be included in the XML file, or specified on the command line when they frequently change. For more information on command line parameters and XML elements, see Command Line - Syntax.
On the DB2 MultiNode Agent host, run the qlogin command to log on to the CommServe computer.
Download the CreatePseudoClientDPF.xml file to the computer where you will run the command.
Open the CreatePseudoClientDPF.xml file, add your specific parameters and save the file.
For information on supported subclient XML parameters, see Available XML Parameters for DB2 Pseudo Client Configuration.
On the command line, go to Software_Installation_Directory/Base and type the following command.
qoperation execute -af $[xml_path]\CreatePseudoClientDPF.xml -appName '$[DB2 MultiNode]' -homeDirectory '$[home_directory_path]' -encryptionFlag $[encryption_value]-domainName '$[domain_name]' -password '$[password]' -userName '$[db_user]' -networkAgents '$[number_network_agents]' -softwareCompression '$[software_compression_type]' -throttleNetworkBandwidth '$[bandwidth]' -dataBackupStoragePolicy/storagePolicyName '$[data_storage_policy]' -commandLineStoragePolicy/storagePolicyName '$[command_strorage_policy]' -logBackupStoragePolicy/storagePolicyName '$[log_srorage_policy]' -generateSignature '$[option]' - dpfpartitionclients nodenum = "$[number]" -nodeClient $[clientName] = "$[client_name]"
Examples
Creating a Pseudo Client
qoperation execute -af CreatePseudoClientDPF.xml -appName '$[DB2 MultiNode]' -homeDirectory '$[E:DB2V9.7SQLLIB]'-encryptionFlag '$[ENC_NETWORK_AND_MEDIA]'-domainName '$[DB2 test]' -password '$[password]' -userName '$[db_user]' -networkAgents '$[3]' -softwareCompression '$[USE_STORAGE_POLICY_SETTINGS]' -throttleNetworkBandwidth '$[250]' -dataBackupStoragePolicy/storagePolicyName '$[SP3]'-commandLineStoragePolicy/storagePolicyName '$[SP_LIB2]' -logBackupStoragePolicy/storagePolicyName '$[SP4]' -generateSignature '$[ON_CLIENT]' -dpfpartitionclients nodenum = "$[1]" -nodeClient $[clientName] = "$[client1]" -dpfpartitionclients nodenum = "$[0]" -nodeClient clientName = "$[client0]"
