System Requirements for the NetApp Storage Array
Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses.
Array
Snapshot Type
License
NetApp
Snapshot
  • FlexClone, installation on the storage array
  • SnapRestore, installation on the storage array
NetApp with SnapVault SnapMirror
SnapVault and SnapMirror
  • SnapVault or SnapMirror for replication, installation on the primary storage array and on the secondary storage array
  • For OnCommand Unified Manager 5.x: Operations Manager, Provisioning Manager, and Protection Manager licenses
  • NetApp Snap management license, installation on the CommServe
NetApp Open Replication
Replica
  • For SnapMirrorCloud Replication: SnapMirror Cloud and S3 SnapMirror licenses
  • For SnapLock Enterprise and Tamperproof: SnapLock Enterprise license
Version and Firmware
Use the following version and firmware.
Array
Version and Firmware for 7-Mode
Version and Firmware for C-Mode
NetApp
  • Product
    • ONTAP / Data ONTAP
  • ONTAP versions
    • ONTAP 7.3.5 or later 7.3.x subversion
    • ONTAP 8.2, 8.1, including subversions
  • Products
    • Cloud Volumes ONTAP
    • ONTAP Select
  • ONTAP versions
    • ONTAP 8.3 and 8.2P3 (or later patch level) including subversions
    • Cluster-Mode ONTAP 8.2.1 NFS configurations require 8.2.1P1 or later patch level with fix for NetApp BURT 806823
    • ONTAP 9.18.1, 9.17.1, 9.16.1**, 9.15.1**, 9.14.1**, 9.13.1, 9.12.1, 9.11.1, 9.10.1, 9.9.1, 9.8, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0
  • Product
  • ONTAP versions
    • ONTAP 8.2, 8.1 including subversions
  • Products
    • ONTAP Select
  • ONTAP versions
    • ONTAP 8.2P3 (or later patch level) and 8.3 including subversions
    • ONTAP 9.16.1**, 9.15.1**, 9.14.1**, 9.13.1, 9.12.1, 9.11.1, 9.10.1, 9.9.1, 9.8, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0
      For SnapVault and SnapMirror configurations, if you are using ONTAP 9.18.1, 9.16.1**, 9.13.1, 9.12.1 or 9.11.1, you can use AIQUM 9.18, 9.16P2***, 9.13*, 9.12* or 9.11* respectively.
  • N/A
  • Products
    • ONTAP Select
  • ONTAP versions
    • ONTAP 9.18.1, 9.17.1, 9.16.1**, 9.15.1**, 9.14.1**, 9.13.1, 9.12.1, 9.11.1, 9.10.1, 9.9.1, 9.8, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.3.2
*The AIQUM version is supported only with specific NetApp patches. For information on the AIQUM version, see the NetApp article and contact NetApp.
**The Active IQ Unified Manager (AIQUM) 9.14 and 9.13P1 are not supported. If you are using AIQUM-based replication, Commvault recommends verifying support from NetApp Interoperability Matrix for ONTAP 9.14.1, 9.15.1, 9.16.1, 9.17.1, and 9.18.1 with AIQUM 9.13* or older. For information on why certain AIQUM versions are not supported, see the NetApp KB articles CAIQUM-5577 and CAIQUM-6267.
*The AIQUM version is field certified. for more information, see the NetApp KB article.
Protocols
Use one of the following protocols.
Array
Protocol
NetApp
  • Fibre Channel
  • iSCSI
  • CIFS, NFS
  • FCoE*
  • NDMP
  • Fibre Channel
  • iSCSI
  • CIFS, NFS
  • FCoE*
  • NDMP
*This protocol is field certified.
Software
Install the following software.
Array
Required Software
NetApp
None
  • To create SnapVault and SnapMirror copies of 7-Mode snapshots, install OnCommand Unified Manager server running OnCommand Unified Manager 5.0, 5.1, or 5.2.
  • For ONTAP 8.1, install OnCommand Unified Manager 5.2 or 5.1.
  • To create SnapVault and SnapMirror copies of clustered Data ONTAP snapshot copies, use OnCommand Unified Manager 9.8, 9.7, 9.6, 9.5, 9.4, 7.3, 7.2, 7.1, 7.0, 6.4P1, 6.3P1, 6.2, 6.1 and 6.0, or Active IQ Unified Manager (AIQUM) 9.16P2**, 9.13*, 9.12*, 9.11*, 9.10, 9.9, 9.8, 9.7, and 9.6. Refer to NetApp Interoperability Matrix Tool (IMT) to verify the latest support for your product configuration.
  • For ONTAP 9.3, install OnCommand Unified Manager 7.3.
**The AIQUM version is field certified. for more information, see the NetApp KB article.
None
Ports
  • For snapshot-based operations, open port 443 (HTTPS) for communication between the NetApp server and CommServe computer, MediaAgent, access node or remote snapshot MediaAgent in your CommCell environment.
  • For SnapDiff V2 and V3, open port 2049 (NFS) for communication between the NetApp server and CommServe computer, MediaAgent, access node, or remote snapshot MediaAgent in your CommCell environment to transfer the file list information over NFS.
  • For NetApp open replication with SnapMirror cloud, open the following ports for communication between the NetApp cluster and the the object store destination:
    • Port 443 (HTTPS) for all the vendors
    • Port 10443 (HTTPS) for StorageGRID.
    For StorageGRID port requirements, see Snap Configuration.
  • For OCUM 6.0, 6.1, 6.2, 6.3P1, 6.4P1, 7.0, 7.1, 7.2, 7.3, 9.4, 9.5, 9.6, 9.7 and 9.8 or AIQUM 9.6, 9.7, 9.8, 9.9, 9.10, 9.11*, 9.12*, 9.13*, and 9.16P2**, open port 443 (HTTPS) between the OCUM server or the Active IQ Unified Manager server and the NetApp server.
  • For OCUM 5.x, open ports 8088 (HTTP) and 8488 (HTTPS) between the OCUM server and the NetApp server.
Licenses for Commvault IntelliSnap for NetApp
When you install the CIFN Enabler License, the backup copy job that is run from the NetApp snap engine is excluded from the backup capacity license calculation.
