Before you configure your storage array, verify that your environment meets the following requirements.
Licenses
Install the following licenses.
Snapshot Type |
License |
Silk (Deprecated) Snap |
None |
Version and Firmware
Use the following versions and firmware.
Array |
Version and Firmware |
Silk (Deprecated) |
Protocols
Use one of the following protocols.
Important
For iSCSI LUNs, configure the host in the same subnet of the storage array.
Array |
Protocol |
Silk (Deprecated) |
Software
Install the following software components:
Array |
Required Software |
Silk (Deprecated) |
None |
Ports
You do not need to open any specific port.
