Commvault Edge Versions and Images
Commvault monitors and tests the updates available for the ${{ cvedge }} on Linux server and if any updates affect the stability and security of the ROBO server, they will be released to customers on a monthly basis.
Verify the latest ${{ cvedge }} versions to see if the Commvault Edge server in your environment need to be updated.
Important
Versions that are older than 3 months are outside of support and will be worked as best effort. It is recommended to regularly update your server to one of the latest 3 versions to ensure supportability. In certain scenarios, to install critical updates, Commvault may require you to update to the latest platform version to resolve any issues."
