Subscription Usage for Power BI
Use the Power BI subscription usage report to monitor Power BI license usage in your Commvault environment.
User count considerations
Commvault calculates Power BI user counts based on the following conditions:
  • The user is a member of the Microsoft tenant. Guest users are not counted.
  • The user has access to Power BI with a valid license or plan.
  • The user is active (not deleted or blocked).
  • The user is not on a Power BI Free license.
  • Users with multiple licenses are counted only once.
Commvault supports a combination of user-based and capacity-based licensing. Usage is calculated based on the licenses assigned in the Microsoft tenant.
User-based licensing
Each Microsoft Power BI Pro or Microsoft Power BI Premium Per User (PPU) license counts as one Power BI user for Commvault.
Capacity-based licensing
Each Microsoft Power BI Premium capacity license counts as 500 Power BI users for Commvault.
  1. From the Command Center navigation pane, go to Manage > Account > Subscription and Usage > Usage.
    The Usage summary page appears, showing a summary of service subscriptions and their usage.
  2. Under Subscriptions, click Power Platform - Enterprise.
    The Power Platform - Enterprise Usage Report appears.
  3. To view information for a specific time frame, click Time frame, and then select one of the time options.
Data usage per month
The Data Usage Per Month chart displays the total Power BI user count. This chart updates when you select a time frame from the Time frame filter.
Monthly usage
The Monthly Usage table displays monthly usage information for each user. This table updates when you click a month bar in the Data Usage Per Month chart.
To filter or export the monthly usage data, use the following options:
  • To hide columns, click the Column button Viewing the Usage Report (1), unselect the columns that you want to hide, and then click Save.
  • To export data, click the Export button Viewing the Usage Report (2), select the export file format, and then save the file to your local computer.
