Changing Ownership of a Credential in Credential Vault
The owner of a credential entity is the user or the user group that has permission to modify the credential entity.
  1. In the CommCell Console, open Credential Vault.
  2. In the Manage Credentials dialog box, select the credential that you want to change from the list, and then click Edit.
  3. In the Modify credential dialog box, click the Security tab, and then click Add.
  4. In the Add Users and Groups dialog box, select a user or user group from the list.
    Tips
    • Use the Domain list to filter the users by domain.
    • Use the Find feature to locate specific users and user groups by keywords.
  5. Click Add.
    The user or user group name appears in the box at the bottom of the dialog box.
  6. From the Please select Role list, select custom role and then select the Use Credential and Modify Credential Account permissions under Credential Manager.
