Enabling this option allows you to perform backups if your laptop is connected to a wired network.
Disabling this option allows the backup of laptops that use the wireless network connectivity.
From the CommCell Console, navigate to Policies | Schedule Policies.
Right-click the <laptop schedule policy> and click Edit.
Select <schedule task> displayed in the Tasks and then click Edit button.
In the Network Management area, enable Use only wired network checkbox.
