When you perform a backup for an offline subclient, the database is shut down.
Configure the DB2 subclient to perform a full backup of the DB2 database when it is offline. Full backups include all data files and tablespaces for the database. Offline backups do not include the archived log files.
You can perform offline backups when the database is either offline or online.
You can configure the subclient to use the DB2 Advanced Copy Services (ACS) interface. When you use the DB2 ACS interface for an IntelliSnap backup, the Commvault software registers the IntelliSnap backup with the DB2 application catalog.
Best Practice: If you create an offline subclient, then you should also create an archive log subclient so that you can avoid the SQL 1042c error. For more information, see SQL1042c DB2 IntelliSnap Windows Restore Goes Pending.
Create a backup set for the DB2 database.
From the CommCell Browser, expand Client Computers > client > DB2 > Instance.
Right-click the backup_set, point to All Tasks, and then click New Subclient.
The Create New Subclient dialog box appears.
On the General tab, in the Subclient name box, type a name for the subclient.
On the Content tab, select the following options:
Select the Data check box.
Select the Offline Database option.
On the Storage Device tab, from the Data Storage Policy list, select the storage policy that you want to use.
On the IntelliSnap Operations tab, do the following:
Select the IntelliSnap check box.
From the Available Snap Engines list, select the engine that matches your snapshot type. For a list of available engines for your array, see Snapshot Engine.
To use the DB2 ACS interface, select the Use DB2 ACS Interface check box.
Optional: Select the subclient options.
Run scripts before or after the backup operation.
You can choose to run the post-process script even if the backup job failed.
To pass the database instance name to the script, see Passing the Instance Name to Pre and Post Scripts for Databases.
On the Pre/Post Process tab:
In the PreBackup Process box, type the full path name for the script.
In the PostBackup Process box, type the full path name for the script.
To run the post backup process regardless of the job's outcome, select the Run Post Process for all attempts check box.
Use compression to optimize backup storage.
On the Advanced Options tab, select the Use Db2 compression check box.
When you select this option, the Commvault software applies the DB2 compression feature to all the backups for this subclient.
Fore more information about DB2 compression, go to the DB2 website, compression and storage.
Use DB2 DEDUP DEVICE
When this is enabled, the DB2 deduplication parameter DEDUP_DEVICE is used. This feature is available starting on DB2 version 9.7 with FixPack 3.
For additional information about the DB2 DEDUP_DEVICE parameter, go to the DB2 Knowledge Center, DEDUP_DEVICE.
On the Advanced Options tab, select the Use Dedupe Device check box.
Configure the number of streams that the software uses for the backup operation.
On the Storage Device tab, click the Data Storage Policy tab, and then in the Number of Data Backup Streams box, type the number of streams that the software uses for the backup.
