Use this dialog box to change configuration parameters that apply to Disaster Recovery Backups.
Pre/Post Process
PreScan Process
If selected, allows you to specify the location for any prescan process data.
Browse
Allows you to browse to a network share or local drive.
PostScan Process
If selected, allows you to specify the location for any post scan process data.
Browse
Run Post Scan Process For All Attempts
If selected, post scan processes will be run for all attempts.
PreBackup Process
If selected, allows you to specify the location for any pre backup process data.
Browse
PostBackup Process
If selected, allows you to specify the location for any post backup process data.
Browse
Run Post Backup Process For All Attempts
Run As
Change
Displays the User Account dialog box, which allows you to establish or change the designated user account information.
