You can enable or disable network zoning by adding the nNO_ZONE_CHECKS additional setting to a client or client group.
To disable the network zoning feature, create a smart client group that contains all clients, and disable network zoning on the entire client group using this setting.
Follow the steps described in Adding or Modifying Additional Settings from the CommCell Console, using the following parameters:
Property
Value
Setting Name
Category
Firewall
Type
Integer
Values
0 Enable (default)
1 Disable
