The Epic electronic health record system (E HR) is a single-database EHR for the healthcare industry, serving mid-size and large medical groups, hospitals, and integrated healthcare organizations. Epic EHR systems use a central Intersystems IRIS/Caché database to manage all patient records and transactions, with secondary reporting databases and presentation servers. The Commvault Epic Solution uses the IntelliSnap technology to take a point-in-time snapshot of the data volume with the database in a fully quiesced state. The software can then automatically create and mount database clones that are used for testing and reporting without any impact on the InterSystems IRIS/Caché databases. The Epic Solution provides full-system backup and restore capabilities for all remaining servers in the Epic environment in the manner that Epic recommends in the Epic Business Continuity Technical Solutions Guide.
Solution Overview
The Epic Solution includes the following server types:
Servers that run the InterSystems IRIS/Caché databases
Servers that run the Epic Clarity Reporting Application
Servers that run other applications the give users access to Epic
You must back up the following data:
IRIS Caché database
IRIS Caché database journal files
IRIS Caché database server root volume and system state
Epic Clarity Reporting Application data
Epic file system data, root volume and system state
InterSystems IRIS/Caché Database
The scope of the solution is the virtual servers that host the InterSystems IRIS/Caché databases and contain volumes that can be snapped at the hardware level.
The Epic Solution protects the InterSystems IRIS/Caché database in a consistent manner. The InterSystems IRIS/Caché database runs on a server that normally contains drives for the following data:
databases
journal files
You can use the UNIX File System Agent or Virtual Server Agent to back up the data.
Epic Clarity Reporting Application Data
The Epic Clarity Reporting Application runs SQL or Oracle.
You can use the SQL or Oracle agent to back up the Epic Clarity Reporting Application data.
Epic File System Protection
For all other servers (those that do not contain an InterSystems IRIS/Caché database or Epic Clarity Reporting Application) and components in the Epic system, you can use the Virtual Server Agent or install the File System Agent and then configure a subclient with the root volume and system state. You can use the Commvault 1-Touch feature for backup and recovery operations.
