Review the technical specifications for the following Commvault HyperScale X Appliance models:
HyperScale X Appliance HS2300
Starting with configurations of either 48, 96 or 168 of raw terabytes capacity, HyperScale X Appliance HS2300 is ideal for small to medium size enterprise environments ready to grow and expand to density, scale, and performance.
HyperScale X Appliance HS4300
Starting with configurations of either 288 or 504 TB of raw terabytes capacity, HyperScale X Appliance 4300 is ideal for enterprise environments that require greater scale and performance.
Specification
HS2300 (per node)
HS4300 (per Node)
System capacity (raw)1
16, 32, or 56 TB
96 or 168 TB
System capacity (useable)2
8.3, 17, or 29 TB
50 or 87 TB
Hard disk drive
4 qty - SAS, 12 GB/s, 4 TB, 7,200 rpm, 512n, hot-plug, 3.5" or
4 qty - SAS, 12 GB/s, 8 TB, 7,200 rpm, 512n, hot-plug, 3.5" or
4 qty - SAS, 12 GB/s, 14 TB, 7,200 rpm, 512n, hot-plug, 3.5"
12 x 3.5” hot-plug 8TB SAS 7200rpm or
12 x 3.5” hot-plug 14TB SAS 7200rpm
M.2-based flash storage
240 GB
2 x 480 GB SSD configured in RAID1
NVMe PCIe capacity
6.4 TB
12.8 TB
Memory
256 GB DDR4
512 GB DDR4
Compute
2 x Intel Xeon Silver 4208 8C 2.10 GHz
2 x Intel Xeon Gold 6230 20 C 2.10 GHz
Chipset
Intel® C622
Intel® C622
On-board network connectivity
4 x 10/25 GbE SFP+
2 x 1/10Gbase-T LAN
1 x 1GbE RJ-45 IPMI ports
4 x 10/25 GbE SFP+
2 x 10Gbase-T LAN
1 x 1 RJ45 IPMI port
1 x 16 Gbits/s Dual Port Fibre Channel HBA
1 x 12 Gbits/s Dual Port SAS HBA
Network Tranceivers
Included SFP+ Network Tranceivers: 4 per node.
For details about Network Transceivers see: https://www.supermicro.com/en/products/accessories/addon/aoc-e10gsfpsr.php
OPTIONAL: 10GBASE-T network cards are available as an option at the time of order placement.
Operating environment
Commvault HyperScaleTM X Software
Add-in cards
OPTIONAL: 16 Gbits/s Dual Port PCIe FC HBA 12 Gbits/s SAS Dual Port PCIe HBA
STANDARD: 16 Gbits/s Dual Port PCIe FC HBA 12 Gbits/s SAS Dual Port PCIe HBA
1 add-in card can be added per node.
Gross Weight
up to 138 lbs
(62.6 kg)
192 lbs (87 kg)
Dimensions
1 rack units
(W x H x D) 17.2 x 1.7 x 25.5 in. (437 x 43.3 x 647-mm)2 rack units
(W x H x D) 17.2 x 3.5 x 25.5 in. (437 x 89 x 647-mm)Power supply
2 x 700W/750W Multi-output power supply w/ PFC for Rear I/O
2 x hot-plug 1200W power supplies with PMBus for redundancy per node
Rated voltage range
100 Vac to 240 Vac
100 Vac to 240 Vac
Frequency
50 Hz - 60 Hz
50 Hz - 60 H
AC Input / Max. rated current
100-127V, 50-60Hz
200-240V, 50-60Hz
100-127Vac / 15-12A / 50-60Hz
200-240Vac / 8.5-7A / 50-60Hz
200-240Vdc / 8.5-7A (for CCC only)
Operating ambient temperature
10°C ~ 35°C (50°F ~ 95°F)
Non-operating temperature
-40°C to 60°C (-40°F to 140°F)
Operating relative humidity
8% to 90% (non-condensing)
Warranty coverage
On-site hardware warranty – next business day
Software maintenance3
Premium software maintenance
Management tools
Commvault Command CenterTM, CLI, easy Setup Wizard
Certification
80 Plus Titanium Level
1 Raw capacity value is calculated using Base10 (i.e., 1 TB = 1,000,000,000,000 bytes) 2 Useable capacity value calculated using Base2 (i.e., 1TB = 1,099,511,627,776 bytes) 3 Software maintenance is based on subscription licensing and pricing
