Use this operation to initiate the upload session for uploading multiple file chunks to Edge Drive. Optionally, you can also send the first file chunk along with the request.
When you initiate an upload session, you can also enable block level file integrity check for the complete file, using Secure Hash Algorithm (SHA) - 256 cryptographic hash function. For more information, see File Integrity Check.
Request
Syntax
POST webservice/drive/file/action/upload?uploadType=chunkedFile&verifyBlockLevelFileIntegrity=true HTTP/1.1
Host: host name
Accept: application/xml
Authtoken: authentication token
ExternalFileGUID: GUID from an external source
FileName: file name in base64 format
FileSize: file size in bytes
FileModifiedtime: modified time in UNIX timestamp
ParentFolderPath: file path in base64 format
ChunkSize:file chunk size in byteswhere <webservice> is the root path used to route the API requests to the Web Server.
For more information, see Available Web Services for REST API.
Request Parameter
Name |
Description |
Required |
verifyBlockLevelFileIntegrity |
Specify the value, true,to enable file integrity check using the combined hash value of all the chunks. |
No |
Request Headers
Name |
Description |
Host |
The host name of the Web Server or Web Console used in the API request. |
Accept |
The format of the response. Valid values are: application/xml or application/json. |
Authtoken |
The authentication token received after successfully logging on. For details on receiving an authentication token, see Authentication. |
ExternalFileGUID |
(optional) If you have a 128-bit globally unique identifier (GUID) outside of the Commvault software, you can add it as a header so that it is assigned as the fileGUID for the file you are uploading. If you send a GUID that includes hyphens, the hyphens are removed. Any request or search that uses your GUID must not include the hyphens. |
FileName |
Name of the file to be uploaded. The name must be base64 encoded. |
FileSize |
Size (in bytes) of the file to be uploaded. |
FileModifiedtime |
The last modified time of the file to be uploaded. Provide the value in UNIX timestamp format (in seconds). For example, 1424813723. |
ParentFolderPath |
The path to the destination folder where the file will be uploaded. The path must be relative from the root path and base64 encoded. |
FileEOF |
Specifies whether the end of file has reached with the current file chunk. Allowed values are 0 and 1. To indicate end of file, enter the value 1. If end of file has not reached, you can skip this header or enter the value 0. |
ChunkSize |
Size (in bytes) of the file chunk to be uploaded. |
Request Body
If you are sending the first file chunk along with the API request, then include the contents of the file chunk in bytes. Do not include the content-type header.
Response
Response Parameters
Parameter |
Description |
Element |
chunkOffset |
The number of bytes received by the Web Server for the uploaded file chunk. |
DM2ContentIndexing_UploadFileResp |
requestId |
A unique identifier for the current upload session. Provide this value as input for uploading the file data chunks. For details, see POST File Data Chunk Upload to Edge Drive. |
errorCode |
The possible error codes. Valid values are:
response |
Examples
Sample Request
Host: client.mydomain.com
Authtoken: QSDK 38568012f4d1e8ee1841d283a47aa3ba78e124ea58354b5fc60f4dab8a63347d05cf5552484dafda3bfa4c5db84e580b1cb37bcf8e65b39f7f8549a443e6f78a2c7be3f31b3d845e24776c835e498e8e883bb40c46bd15af4f40ca94e823acedcdd4e9659e74b34a07a85c4586cd2ed914b6dce015874783ef768fda78183a4208930954a377f66eb56c8b92cexampl4s437a19317ca6ce7f3233d5a01aca35dbad93468b833f2cf71010809006a937670adce711ca8be46638e8
FileName: VHVsaXAuanBn
FileSize: 845941
FileModifiedtime: 1424813723
ParentFolderPath: XHBpY3R1cmVz
ChunkSize: 154231Supported Error Codes
Code |
Status |
Description |
400 |
Bad Request |
The request is missing required headers or file content in the request body. Make sure the parameter values and format in the header request are correct. For example, the header request for file modified time must be specified in UNIX timestamp format (in seconds). Specifying a millisecond value will return an error. Also, the name must be base64 encoded. |
403 |
Forbidden |
The user does not have rights to upload the file or the upload operation is disabled by the administrator by disabling backup activity from the CommCell Console. |
409 |
Conflict |
An upload operation is already in progress for the same file. The response body will have the existing requestId and the number of bytes that the web server has already received for the file. For example:
When a conflict occurs,
