Use XML to modify DB2 subclient properties. Run the operation from the command line, or automate configuration by combining command line operations in a script.
The XML parameters can be included in the XML file, or specified on the command line when they frequently change. For more information on command line parameters and XML elements, see Command Line - Syntax.
On the DB2 Agent host, run the qlogin command to log on to the CommServe.
Download the UpdateSubclient.xml file and save it on the computer from where you will run the command.
Open the UpdateSubclient.xml file, add your specific parameters and save the file.
For information on supported subclient XML parameters, see Available XML Parameters for DB2 Subclient Configuration.
On the command line, go to Software_Installation_Directory/Base and type the command.
UNIX
qoperation execute -af UpdateSubclient.xml -appName 'DB2 on Unix' -clientName 'client1' -instanceName 'dbname' -backupsetName 'backupset_name'-subclientName 'subclient_name'Windows
qoperation execute -af UpdateSubclient.xml -appName 'DB2' -clientName 'client1' -instanceName 'dbname' -backupsetName 'backupset_name'-subclientName 'subclient_name'
Examples
Modifying the Storage Policy and Deduplication on a Subclient on Windows
Note: You must set the enableDeduplication parameter to 'true' when you use the generateSignature parameter.
To modify a subclient Storage Policy (in this example, the software compression will use the Storage Policy Settings and deduplication is enabled with the signature on the MediaAgent), set the following parameters:
 Parameter  |
 Value  |
 storagePolicy  |
 'the data storage policy  |
 enableDeduplication  |
 'true'  |
 generateSignature  |
 'ON_MEDIA_AGENT'  |
 dataBackupStoragePolicy/storagePolicyName  |
 Storage Policy Name (in this example, 'data_sp').  |
 appName  |
 In this example, 'DB2'.  |
qoperation execute UpdateSubclient.xml -appName 'DB2' -clientName 'client1' -instanceName 'Instance001' -backupsetName 'test_backup_set'-subclientName 'subclient1' -enableDeduplication true -generateSignature ON_MEDIA_AGENT -dataBackupStoragePolicy/storagePolicyName 'data_sp'
Modifying the Storage Policy and Deduplication on a Subclient on UNIX
 Parameter  |
 Value  |
 storagePolicy  |
 'true'  |
 generateSignature  |
 'ON_MEDIA_AGENT'  |
 appName  |
 In this example, 'DB2 on Unix'.  |
qoperation execute UpdateSubclient.xml -appName 'DB2 on Unix' -clientName 'client1' -instanceName 'Instance001' -backupsetName 'test_backup_set'-subclientName 'subclient1' -enableDeduplication true -generateSignature ON_MEDIA_AGENT -dataBackupStoragePolicy/storagePolicyName 'data_sp'
Renaming a Subclient on Windows
To rename a subclient, set the following parameters
 Parameter  |
 Value  |
 newName  |
 In this example "subclient1a"  |
 appName  |
qoperation execute UpdateSubclient.xml -appName 'DB2' -clientName 'client1' -instanceName 'Instance001' -backupsetName 'test_backup_set'-subclientName 'subclient1' -newName 'subclient1a
Renaming a Subclient on UNIX
 Parameter  |
 Value  |
 newName  |
 appName  |
qoperation execute UpdateSubclient.xml -appName 'DB2 on Unix' -clientName 'client1' -instanceName 'Instance001' -backupsetName 'test_backup_set'-subclientName 'subclient1' -newName 'subclient1a
Configuring the Subclient to Use the DB2 Deduplication Parameter
To modify a subclient so that the Commvault software uses the DB2 deduplication parameter, set the following parameters:
 Parameter  |
 Value  |
 db2UseDedupeDevice  |
 'true'  |
 appName  |
qoperation execute UpdateSubclient.xml -appName 'DB2 on Unix' -clientName 'client1' -instanceName 'Instance001' -backupsetName 'test_backup_set'-subclientName 'subclient1' -db2UseDedupeDevice true
