When you enable the application-aware installations, the software detects third-party applications that are installed on the client in the past 24 hours.
After the software detects the third-party applications, run the predefined workflow to install the Commvault software packages for each application. For example, if the Commvault software detects the Oracle application, the workflow installs the Oracle Agent on the client.
You can schedule the workflow, or manually execute the workflow from the CommCell Console.
How Does It Work?
The predefined workflow automates the following operations:
Installing the Commvault package for the third-party application if it does not exist on the client.
Configuring the client on the CommServe computer.
Registering the client with the CommServe computer with the Product Status as 'Auto Detect'.
From the CommCell Browser, go to Workflows.
Right-click InstallAutoDiscoveredApps and then click All Tasks > Execute.
The InstallAutoDiscoveredApps Options dialog box appears.
Decide which clients to install the software on:
To install the detected software on all clients in a client group, select the client group from the ClientGroup list.
To install the detected software on a specific client, select the client from the ClientName list.
On the Job Initiation tab, specify whether to run the workflow now or if it will be scheduled.
Best Practice: Select Schedule.
For information on configuring a workflow backup schedule, see Schedule Workflows.
You can track the progress of the workflow job from the Job Controller. For instructions on using the Job Controller, see Getting Started with the Job Controller.
