You can run workflows from the CommCell Console.
Workflows must be deployed before they can be executed. For instructions on deploying a workflow, see Deploying a Workflow.
From the CommCell Browser, go to Workflows.
The Workflows window appears in the pane on the right.
Right-click the workflow, and then click All Tasks > Execute.
From the Run workflow on list, select the engine to use to execute the workflow and then provide values for the workflow inputs.
If you select Any, the workflow engine with the latest deployed version of the workflow is used.
You can track the progress of the workflow job from the Job Controller tab.
