You can configure the CommCell Console to disconnect users who are inactive for a user-defined amount of time. By default, the connection timeout in the CommCell Console is disabled.
From the CommCell Console ribbon, click the Home tab, and then click Control Panel.
In the CommCell section, click System.
The System dialog box appears.
On the General tab, select the Allow GUI connections to timeout check box.
In the GUI Timeout in minutes box, type the timeout interval in minutes.
