Use the General tab to view or provide general information and user account information about the subclient.
Client Name
The name of the client computer to which this subclient belongs.
iDataAgent or Agent Type
The name of the agent to which this subclient belongs.
Backup Set
The name of the set to which this subclient belongs.
Subclient Name
The name of the selected subclient. You can modify the name of the subclient.
Maximum streams that can be used
The maximum number of streams used to archive multiple mailboxes in parallel.
User Mailbox and Journal Mailbox: Each access node that is associated with the Exchange Mailbox client can have a maximum of 20 streams for each job. However, one service account can only use a maximum of 15 streams regardless of the value set for the subclient. If you need to use a high number of streams, use more than one service account.
ContentStore Mailbox: We recommend that you use five streams on each access node.
Enter a description about the entity. This description can include information about the entity's content, cautionary notes, and so on.
