System Requirements for MongoDB
Verify that your environment meets the system requirements.
All Environments
  • All mongod and mongos instances must run with configuration files in the YAML format.
  • If the ports between the master node and the other cluster nodes are blocked, the nodes must connect through a firewall.
  • If the client name and the MongoDB host name differ, then the MongoDB host name must resolve to an IP address accessible by Commvault and is included in the MongoDB bind_ip setting.
  • The security.keyFile parameter value must be identical across cluster nodes.
Linux Environments
  • Database authentication is supported on both Windows and Linux for full backups. Authentication is supported only on Linux for incremental backups.
  • For MongoDB deployments with authentication enabled, use a database user with one of the following:
    • root role on the admin database (superuser)
    • backup, restore, and clusterAdmin roles on the admin database as an alternative to superuser access.
  • Logical Volume Manager (LVM) volume groups must have sufficient free space for creating the IntelliSnap snapshots. The default COW cache size is set to 4096 MB or 5% of the volume size, whichever is greater. You can increase the COW cache size.
Replica Set Environments
Replica sets must have at least one secondary node.
If you have a single node replica set that has only a primary node, add the bMongoDBEnableBkpForSingleNodeRepSet additional setting to the client node that you want to back up.
Protect Encrypted Database
The Commvault software protects MongoDB Replica Set clusters with encrypted databases. MongoDB clusters must use a local master encryption key file on all the nodes to encrypt the databases. You must configure the bMongoDbEnableBkpEncryptionKey additional setting on all MongoDB clients for backup and restore operations. During discovery or a full backup, the key file is backed up from the source master node.
All nodes of the cluster must have the same key file contents.
  • For encrypted database restores, the Commvault software does following:
    • In-place restore
      • Restores the key file to its original location.
      • Automatically renames the existing key file.
    • Out-of-place restore
      • Restores the key file to all destination clients.
      • Creates the key file path if it does not exist.
    • Granular restore
      • Creates the key file on the 3DFS share used to start the staging server.
  • Enable the encryption setting on destination clients only when restoring from an encrypted backup.
The Encryption at rest support feature that is enabled by bMongoDbEnableBkpEncryptionKey is only supported for replica set clusters.
Sharded Cluster Environments
  • The same database user must be created on all shard servers and the config server.
  • Each sharded server must be a replica set, and the replica set must have at least one secondary node.
  • The Commvault software is not required on the arbiter node.
Supported MongoDB Versions
MongoDB version 8.x, 7.x, 6.x, 5.x, 4.4.x, 4.2.x, 4.0.x, 3.6.x, 3.4.x, 3.2.x MongoDB Enterprise edition, MongoDB Community edition, and Percona Server for MongoDB versions 7.x, 6.x, 5.x, 4.4.x, 4.2.x.
  • Starting from MongoDB 4.4, the mongodump and mongorestore utilities must be downloaded separately and copied to the bin path.
  • MongoDB 7.0 and Percona 7.x is supported only from CPR2023E (11.32) Maintenance Release 55 or higher.
  • The most recent certified version on MongoDB 7.x is 7.0.14.
  • The most recent certified version of Percona Server for MongoDB 7.x is 7.0.14-8.
Operating Systems and Processor Architectures
Linux
Operating system
Processor architectures
Amazon Linux 2
  • x64
  • Compatible processors
Debian 10 and more recent versions of 10
x64
Oracle Linux 9.x
x64
Oracle Linux 8.x
x64
Red Hat Enterprise Linux/CentOS 8.x with glibc 2.17.x
  • x64
  • PowerPC (little endian)
Red Hat Enterprise Linux/CentOS 7.x with glibc 2.17.x
  • x64
SuSE Linux 12 (Initial Release/SP1 and later SPs) with glibc 2.19.x and higher
x64
SuSE Linux 15 (Initial Release/SP1 and later SPs) with glibc 2.26.x and higher
x64
Ubuntu 20.04 LTS
x64
Ubuntu 18.04
x64
Ubuntu 16.04
x64
Windows
Operating system
Windows Server 2019
All Windows-compatible processors
Windows 2016
Windows 2012
Access Node Requirements for Backup Copy Operations
The following are hardware specifications for access node to perform file system backup copy operations for MongoDB backups.
Components
Extra Large
Large
Medium
Small
Extra Small
CPU/RAM 1
16 CPU cores, 128 GB RAM (or 16 vCPUs/128 GB)
12 CPU cores, 64 GB RAM (or 12 vCPUs/64 GB)
8 CPU cores, 32 GB RAM (or 8 vCPUs/32 GB)
4 CPU cores, 24 GB RAM (or 4 vCPUs/24 GB)
2 CPU cores, 16 GB RAM (or 2 vCPUs/16 GB)
Front End Terabytes (FET) 2
90 TB to 120 TB
50 TB to 100 TB
25 TB to 50 TB
10 TB to 25 TB
5 TB to 10 TB
  1. Assumes latest generation CPU architecture.
  2. Front-End Terabytes (FET): Size of the data on the client computer that has to be backed up.
