Verify that your environment meets the system requirements.
Operating System
The following operating systems are supported:
AlmaLinux 8.x
Oracle Linux 7.x
Oracle Linux 8.x
Oracle Linux 9.x
RHEL 7.6 to 7.9, and their corresponding CentOS releases
RHEL 8.0 to 8.10 (Python 3.6), and their corresponding CentOS releases
RHEL 9 and RHEL 9.2, and their corresponding CentOS releases
Rocky Linux 8.x
Ubuntu 20.04
Programming Language
Python 2.7
Customized SELinux Module
If you already customized the SELinux module that is present on a Linux MediaAgent, then you cannot use the ransomware protection feature.
Packages
- libselinux-python
For RHEL 8.x and 9.x, install python3-libselinux instead.
- policycoreutils-devel
 - psutil
 - selinux-policy
 - selinux-policy-devel
 - selinux-policy-targeted
To verify the presence of the above packages in your environment, execute the following command:
rpm -qa | egrep 'libselinux-python|policycoreutils-devel|psutil|selinux-policy|selinux-policy-devel|selinux-policy-targeted|python3-libselinux'
For a HyperScale MediaAgent, you must upgrade the operating system to install the above packages. For more information about installing operating system updates on HyperScale, see related documentation:
Packages for MediaAgent on Ubuntu 20.04
If the MediaAgent is on Ubuntu 20.04 operating system, you must install the following packages:
- policycoreutils
 - selinux-utils
 - selinux-basics
 - python3-selinux
Execute the following command to install the packages:
apt install policycoreutils selinux-utils selinux-basics selinux-policy-dev python3-selinux
Folders That Must Not Contain the Library or the Mount Path
Verify that the library or the mount path is any folder other than the following folders. which have pre-configured security policies that do not support ransomware protection:
- /home
 - /var
 - /etc
 - /usr
 - /root
Shared Library
If a disk library is shared with another MediaAgent, then you must enable the ransomware protection on all the MediaAgents.
