Maximum read, write throughputs to cloud storage can be throttled during certain periods, like the peak business hours.
To the MediaAgent computer or the client computer with Storage Accelerator, add the additional settings as shown in the following table.
For instructions about adding an additional setting from the CommCell Console, see Adding an Additional Setting from the CommCell Console.
 Additional Setting  |
 Category  |
 Type  |
 Value  |
 MediaAgent  |
 Integer  |
 Enter the number of bytes (in MB) that can be sent by all upload processes in an hour.  |
 MediaAgent  |
 String  |
 Enter the hours during which the nCloudGlobalMaxSendMBPerHour additional setting must be applied.  |
 MediaAgent  |
 Integer  |
 Enter the number of bytes (in MB) that can be received by all processes in an hour.  |
 MediaAgent  |
 String  |
 Enter the hours during which the nCloudGlobalMaxRecvMBPerHour additional setting must be applied.  |
 MediaAgent  |
 Integer  |
 Enter the total number of concurrent upload threads in a single process, globally for all files to the Cloud Servers. Note Increasing the threads will speed up the backups, but will also result in more memory and CPU consumption.  |
 MediaAgent  |
 String  |
 Enter the days in which the nCloudGlobalMaxSendMBPerHour to set the throttling control for sending data, to specific days.  |
 MediaAgent  |
 String  |
 Enter the days in which the nCloudGlobalMaxRecvMBPerHour to set the throttling control for receiving data, to specific days.  |
