You can also use wildcards to define content and filters for a subclient. The following table describes how to use wildcards while defining the subclient content/filters:
If the subclient content consists of wildcard characters and no eligible files are found to back up, then the backup operation successfully completes even though no files were backed up.
When you use wildcards to specify subclient content, the content path appears in italics.
You can use more than one type of wildcard to define subclient content (for example, /Dcvol?/oracle[1-47]/**/*.log).
To treat wildcard symbols as literals in the subclient content and not as wildcards, escape the character by adding a back slash (\). For example, /Report\[2011-2012\]/*.doc backs ups all .doc files under /Report[2011-2012].
Wildcards
 Wildcards
 Examples
Used to match all objects.
Back up all files of a specific extension.
Back up all files under a specific directory.
Back up all files of a specific extension where the file name starts with a specific pattern.
*.doc backs up all files with the extension .doc (for example, status.doc, mission.doc) on all partitions and paths on the client computer.
Subclient content that does not start with /, will be prefixed with /**/ so the content will match at any level. For example, *.doc will be /**/*.doc.
/Test/*.doc backs up all .doc files only in the /Test directory.
a*.so backs up all files which start with "a" and with the extension .so (for example, alsvc.so, advdcc.so) on the client computer.
 Matches any directory level.
 Matches any one character.
