The following table describes the supported Sybase backup and restore parameters.
 Parameter  |
 Parameter Values  |
 taskFlags/disabled  |
 The option to disable the schedule. Valid values are:
 policyType  |
 The storage policy type. A valid value is DATA_PROTECTION.  |
 innitiatedFrom  |
 Where the restore is initialed from (for example CommCell Console, or command line). A valid value is COMMANDLINE.  |
 backupsetName  |
 The name of the backup set.  |
 clientName  |
 The name of the client computer, as displayed in the CommCell Console where the instance is located.  |
 appName  |
 The name of the application, 'Sybase'.  |
 instanceName  |
 The name of the Sybase instance.  |
 subTaskType  |
 The sub task. Valid values are:
 operationType  |
 The type of task. Valid values are:
 backupLevel  |
 The type of backup to perform Note: You can only perform a differential backup on a Sybase server that runs Sybase 15.7 SP100 or later. Valid values are:
 createNewIndex  |
 The option to create a new index. Valid values are true false  |
 followMountPoints  |
 The option to follow the mount points. Valid values are true false  |
 useCatalogServer  |
 The option to use a catalog server. Valid values are true false  |
 enforceTransactionLogUsage  |
 The option to use the transaction logs for granular restarts. Valid values are true false  |
 skipConsistencyCheck  |
 The option to skip the consistency check. Valid values are true false  |
 runIncrementalBackup  |
 The option to run an incremental backup. Valid values are true false  |
 incLevel  |
 The incremental level. Valid values are:
 doNotTruncateLog  |
 The option to not truncate the logs. Valid values are true false  |
 sybaseSkipFullafterLogBkp  |
 The option to skip a full backup for new Sybase databases after a log backup. Valid values are true false  |
 commCellId  |
 The CommCell ID of the CommServe. A valid value is 2.  |
 timeRange  |
 The following values can be used to define the given parameter:
 noImage  |
 The option to include deleted items in the browse. Valid values are:
 useExactIndex  |
 The option to use the index associated with the data protection operation performed at a specific time or the latest index. Valid values are:
 copyPrecedence  |
 The backup copy precedence.  |
 copyPrecedenceApplicable  |
 Valid values are:
 drive  |
 The name of the drive in the pool that performs the restore.  |
 drivePool  |
 The name of the drive pool that performs the restore. Use this option to restore by using a specific drive.  |
 library  |
 The name of the library that performs the restore. Use this option to restore by using a specific library.  |
 mediaAgent  |
 The name of the MediaAgent that performs the restore.  |
 library  |
 The library to use for the restore.  |
 mediaAgent  |
 The MediaAgent to use for the restore  |
 destClient/clientName  |
 The destination client name.  |
 destClient/instanceName  |
 The destination instance name  |
 sybaseRecoverType  |
 The recovery type. A valid value is STATE_RECOVER.  |
 pointInTime/timeValue  |
 The date and time to use for a point-in-time recovery to a specific log Sample values:
 pointofTime  |
 The option to perform a point-in-time restore. Valid values are:
 overWrite  |
 fromTime  |
 The time to restore from. Sample values:
 refTime  |
 destinationServer/name  |
 The name of the server that is the restore destination.  |
 instanceRestore  |
 The option to restore the instance. Valid values are:
 sybaseDatabase/databaseId/name  |
 The Sybase database name.  |
 sybaseDatabase/creationTime  |
 The time that the Sybase database was created.  |
 sybaseDatabase/subclient  |
 The subclient that is associated with the Sybase database.  |
 sybaseDatabase/devices  |
 The devices that are associated with the Sybase database. A colon (:) separated field that has 8 fields
 databaseChain  |
 A colon (:) separated field that has 4 fields.
 renameDatabases  |
 The option to rename the database Valid values are:
 restoreOptions  |
 The option to restore the database Valid values are:
 restoreType  |
 The type of restore to perform. Valid values are:
 onePassRestore  |
 The option to perform a OnePass restore. Valid values are:
 sybaseCreateDevices  |
 The option to create the Sybase devices. Valid values are:
 startInSuspendedState  |
 The option to start the database in a suspended state. Valid values are:
 priority  |
 The job priority  |
 jobDescription  |
 The job description.  |
