Verify that your environment meets the system requirements for Active Directory.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Operating system |
Processor architecture |
Windows Server 2022 Core Editions |
All Windows-compatible processors are supported |
Windows Server 2022 Editions |
Windows Server 2019 Core Editions |
Windows Server 2019 Editions |
Windows Server 2016 Core Editions |
Windows Server 2016 Editions |
Hard Drive
Component |
Space required |
Software |
1 GB |
Job results folder |
256 MB |
Log folder |
256 MB |
Memory (RAM)
2 GB or more
Port Requirements
The standard Lightweight Direct Access Protocol (LDAP) port 389 is used between Active Directory and the destination MediaAgent or CommServe to perform backup.
Software That Is Automatically Installed
File System Agent
The file system agent is automatically installed during the installation of this software, if it is not already installed. For file system system requirements, see the following: System Requirements - Microsoft Windows File System Agent.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Microsoft Windows 10 and Windows Server 2016, because these versions have the Universal C Runtime already installed.
KB2919355
KB2939087
KB2975061
KB2999226
DISCLAIMER
