Use XML to add SAP HANA pseudo-clients. Run the operation from the command line, or automate configuration by combining command line operations in a script.
You can include the XML parameters in the xml file, or you can specify them on the command line when they frequently change. For more information on command line parameters and XML elements, see Command Line - Syntax.
Download the new_hana_client.xml file to the computer where you will run the command.
Open the new_hana_client.xml file, add your specific parameters, and save the file.
For information on supported pseudo-client XML parameters, see XML Parameters for SAP HANA Pseudo-Client Configuration.
On the command line, go to Software_Installation_Directory/Base and type the command.
qoperation execute -af new_hana_client.xml -clientInfo/clientType 'DISTRIBUTED_DATABASE_CLIENT' -entity/clientName 'client_name' -
After the job completes, run the qlogout command to log off the CommServe computer.
Examples
Add a SAP HANA pseudo-client
To add a pseudo-client, set the entity/clientName parameter. Set the following elements:
Parameter |
Value |
clientInfo/clientType |
DISTRIBUTED_DATABASE_CLIENT |
entity/clientName |
The SAP HANA physical client name (in this example, 'hana03SI1') |
qoperation execute -af new_hana_client.xml -clientInfo/clientType 'DISTRIBUTED_DATABASE_CLIENT' -entity/clientName 'hana03SI1'
