Addressing Cleanup Issues
If cleanup operations driven by the retention settings do not remove enough index data to satisfy the free space requirement (the Clean up until free space is at least n percent setting), you have the following options:
To determine how much disk space is currently allocated and being used, and to change your retention settings (if necessary), perform the following steps:
  1. From the CommCell Browser, expand Storage Resources > MediaAgents.
  2. Right-click the MediaAgent_name > Properties > Catalog.
  3. Change the retention parameters settings if needed.
  4. Click OK.
