Advanced Configuration - OpenVMS File System iDataAgent
Proxy Client - A physical computer separate from the host computer on which the iDataAgent is installed. In this case, the Linux computer on which the File System iDataAgent is installed. This will act as a proxy to communicate with the OpenVMS client and facilitates data movement from the OpenVMS client to the backup media.
Client - The OpenVMS computer which contains the data to be secured.
Subclient - A logical entity that uniquely defines a unit of data on a client computer.
Backup Set - A group of subclients which includes all the data backed up by the iDataAgent.
understanding_commcell
A default backup set is created as soon as the OpenVMS client is created. The default backup set includes a default subclient which will backup all the devices and data in the OpenVMS client.
You can create user defined backup sets to group a set of selected data. A user defined backup set will contain its own default subclient.
Creating a User Defined Backup Set
  2. Right-click Proxy Client File System and select All Tasks | Create New Backup Set.
  3. In the New Backup Set Name box, type a name.
  4. Click OK.
    user_bkpset
By default, a default subclient is created when the iDataAgent is installed. This default subclient contains all the devices along with supported file system types.
Use the following steps to create a user-defined subclient to backup specific files:
  1. From the CommCell Browser, navigate to Client Computers | <Client> | Proxy Client File System | <Backup Set>.
  2. Right-click the <Backup Set>, point to All Tasks and then click New Subclient.
  3. In the Subclient name box, type a name.
  6. Click the Content tab.
  7. Click Add Paths.
  8. Type the file or directory to be backed up and click OK.
    For example, /SCS1$DKA800/files/restore.
    Repeat this step to include all the files and directories to be backed up. You can either browse and select or type the content path, but make sure the path is in the UNIX File System format.
  9. Click OK.
Wildcards
Examples
Any number of characters.
  • Back up all files of a specific extension
  • Backup all files under a specific directory
  • Backup all files of a specific extension where the file name starts with a specific pattern.
*.doc will backup all files with the extension .doc (e.g., STATUS.doc, MISSION.doc).
/SCS1$DK00/TEST/*.doc;1 will backup all .doc files only in the /TEST directory
A*.so will backup all files with the extension .so (e.g., ALVSC.so, ADVDCC.so) on the client computer which have the name beginning with "A".
/SCS1$DK00/FINANCE/TEST/* will backup all the files and directories in the "TEST" directory under the "FINANCE" directory. Any sub-directories under the TEST directory will not get backed up.
Any one character.
This wildcard can be used in the following scenario:
All files (or directories) for which any one character in the file name or the directory name is variable.
/SCS1$DK00/ACCESS? will backup any directory or file for which the name begins with- "ACCESS" followed by any one character such as ACCESS1 or ACCESS5. However, ACCESS12 or ACCESS15 will not backup because the last two characters in the name are variable.
/SCS1$DK00/CLASS/REPORT? will backup any directory or file under /CLASS directory for which the character in the place of ? is variable. For example: /CLASS/REPORT1 and /CLASS/REPORT2 will back up. However, /CLASS/REPORT15 will not get backed up.
Set or range of characters.
/SCS1$DK00/CLASS/[A-M]*.doc will back up any file with .doc extension for which the name begins with the letters "A" through "M”.
/[AEIOU]*.doc will back up any file name that ends with .doc and begins with the letters A, E, I, O, or U.
/SCS1$DK00/CLASS/FINANCE/REPORT[1-47-9] will backup files REPORT1, REPORT2, REPORT4, REPORT7, REPORT8, REPORT9 under FINANCE directory.
/SCS1$DK00/DEPARTMENT-[A-CS] will backup files DEPARTMENT-A, DEPARTMENT-B, DEPARTMENT-C and DEPARTMENT-S.
The negation of a set or range of characters. You can use the wildcard in the following scenario:
/SCS1$DK00/TEST/[!AEIOU]*.doc would backup all .doc files in the TEST directory that start with a letter other than A, E, I, O, or U.
Any number of characters across any number of path levels.
/SCS1$DK00/**/MOVE.cpp - will backup the file named MOVE.cpp located at any directory level. (e.g., /TEST/NEWAPP/MOVE.cpp and /OPT/KDE3/SRC/MOVE.cpp)
/SCS1$DK00/ETC/** - will backup all directories and files under /ETC. All the sub-directories under these directories will also be included.
  • If you want all the files with the file extension .doc to be backed up from any level, then specify the content as *.doc. If any subclient content doesn’t start with /, then /**/ will be prefixed to the content to match at any level. E.g., *.doc will be /**/*.doc.
  • If user wants to treat *, ?, [ ] as literals in the subclient content and not as wildcards, then the user can escape the wildcard by adding \ before the wildcard. E.g., /REPORT\[2011-2012\]/*.doc backups all the .doc files under /Report[2011-2012].
More than one type of wildcard can be used when specifying subclient content (e.g., /DCVOL?/ORCL[1-47]/**/*.log).
  7. Click Add Paths, and type the path. Make sure the path is in the UNIX File System format.
    For example, if the path is /SCS1$DKA800/document*, then specify the path as /SCS1$DKA800/document\*.
  8. Click OK.
Creating a Subclient for On-Demand Backups
On-demand backups allow content to be specified as an external input when starting a backup. Traditional backups are performed by using subclients, which contain fixed content configured prior to performing the backup operation, whereas on-demand backups allow you to specify content each time you perform a backup.
Important: After you create an on-demand subclient, you cannot change it to a traditional user-defined subclient.
You must create the following text files to specify the content for on-demand backups:
  • A content file, which is a text file that defines the location of the data that you want to back up. The path can be in either OpenVMS style or UNIX style.
    Content file entries must be in the following format with no filters, wildcards, or regular expressions included:
    DKA0:[USERDATA]TEXTFILE.TXT
    DKA0:[USERDATA]DOCFILE.DOC
    DKA0:[USERDATA.PDFFILES]
    UNIX-style path format:
    /DKA0/USERDATA/DATAFILE.DAT
    /DKA0/USERDATA/TEXTFILE.TXT
    /DKA0/USERDATA/DOCFILE.DOC
  • A directive file, which is a text file that defines where each content file is located. Only one directive file is needed for a single on-demand backup. The path can be in either OpenVMS style or UNIX style.
    Directive file entries must be in the following format with no filters, wildcards, or regular expressions included:
    DKA0:[USERDATA]CONTENT-FILE1.TXT
    /DKA0/USERDATA/CONTENTFILE1.TXT
Prerequisites
  • Create one or more content files defining the content to be backed up.
  • Create a directive file defining the locations of each content file.
  1. From the CommCell Browser, expand Client Computers> client > Proxy Client File System.
  2. Right-click the appropriate backup set, point to All Tasks, and then click New On Demand Subclient.
    1. In the Subclient Name box, enter a name (up to 32 characters) for the subclient.
    2. On the Content tab, select the directive file defining the locations of each content file.
    3. On the Storage Device tab, in the Storage Policy list, click a storage policy name to associate with the subclient.
    4. Click OK.
You must perform a backup of the on-demand subclient. For instructions, see On-Demand Backups.
Modifying the Client Name or Host Name
You can modify the client configuration parameters such as the client name, host name, access node name and so on.
  1. From the CommCell Browser, navigate to Client Computers > client.
  2. Right-click the client and then click Properties.
  3. Click Edit.
    The Edit Client Name dialog box appears.
  4. In the Client Name box, type the new client name.
  5. In the Host Name box, type the new host name.
Changing the OpenVMS User Account
By default, the user account provided at the time of OpenVMS client creation is used for backups. You can change the OpenVMS user account at the client level.
  1. Log on to the OpenVMS client as SYSTEM user.
  2. Go to the software installation folder and type the following command to stop the Commvault services:
    @DKA0:[SIMPANA.BIN]CVOV_STOP.COM
  3. From the CommCell Console, expand Client Computers.
  4. Right-click the appropriate client, and then click Properties.
  5. Click Edit.
    The Edit OpenVMS Client Configuration dialog box appears.
  6. In the OpenVMS User Credentials area, click Change.
    The Enter User Name and Password dialog box appears.
  7. In the User Name box, type the new OpenVMS user account.
    Ensure that the new OpenVMS user account has access to the job results and log directories.
  8. In the Password box, type the password for the new OpenVMS user account, and then reenter it in the Confirm Password box.
  9. Click OK.
The next backup job will use the new OpenVMS user account.
Configuring Backups for Locked Files and Disaster Recovery Operations
By default, files that the OpenVMS operating system locks, are not backed up. Files are usually locked because they are actively being updated by another process. The backed-up data from such a file might be incomplete and result in an inconsistent restore.
You can enable a locked file backup.
  1. Edit the CVOV_CONFIG.DAT file that is in the Commvault directory (for example, DKA0:[SIMPANA]), and add the following entries under the IDA section:
    {backupLockedFile=1}/``{defaultToBlockIO=1}/``{stagingAreaForLockedFiles=DKA0:[STAGING]}/
    Notes:
    • Provide the full path to the staging area for locked files in either the OpenVMS style or UNIX style. The example staging directory is for illustrative purposes. Use values that pertain to your environment.
    • If your backup set includes files from an ODS-5 format disk, then the staging area for locked files must be set to a directory on an ODS-5 format disk.
    • If there is a space restriction, you can specify any accessible disk for the staging area. The directory name must be added in the CVOV_CONFIG.DAT file by the Administrator. Non-system disks must be mounted with the /SYSTEM option.
    Sample CVOV_CONFIG.DAT file content:
    [Base]
    {listenQueue=20}/
    [IDA]
    {stagingAreaForLockedFiles=SYS$SYSDEVICE:[STAGING]}/
    {backupOfflineContent=0}/
    {enableHlinkRestore=1}/
    {encodeAllSpecialSymbols=-1}/
    {PerfCounter=0}/
    {sortCollectFIle=1}/
    [logger]
    {CLIENTBACKUP_DEBUGLEVEL=0}/
    {CLIENTBACKUP_MAXLOGFILEBACKUPS=1}/
    {CLIENTBACKUP_MAXLOGFILESIZE=5}/
    {CLIENTRESTORE_DEBUGLEVEL=0}/
    {CLIENTRESTORE_MAXLOGFILEBACKUPS=1}/
    {CLIENTRESTORE_MAXLOGFILESIZE=5}/
    {CLIENTSCAN_DEBUGLEVEL=0}/
    {CLIENTSCAN_MAXLOGFILEBACKUPS=1}/
    {CLIENTSCAN_MAXLOGFILESIZE=5}/
    {DubToConsole=0}/
    {LaunchD_DEBUGLEVEL=0}/
    {LaunchD_MAXLOGFILEBACKUPS=1}/
    {LaunchD_MAXLOGFILESIZE=5}/
    The sample file content shows the staging area on the current system device.
  2. Save the CVOV_CONFIG.DAT file, and then exit the editor.
    You do not need to restart the Commvault service .
Hard links are not restored by default. Use the following steps to successfully restore hard links.
  1. Enable hard links on all volumes to be backed up.
  2. Edit the CVOV_CONFIG.DAT file that is in the Commvault directory (for example, DKA0:[SIMPANA]), and add the registry under the IDA section:
Hard links are automatically set on files or directories during the restore operation.
  • nfs
  • cifs
However, you can include them in backups by adding the skipped file systems to a specific subclient using the following steps:
  3. Click the Content tab.
  4. Click Add Paths. Enter the NFS or CIFS path.
  5. Click OK.
Configuring Backups for Clients with MultiNet TCP/IP Software
OpenVMS clients run HP TCP/IP software for implementing the TCP/IP services by default. However, you can enable support for backing up clients running MultiNet TCP/IP software by configuring an additional setting on the Linux proxy computer.
  • To the Linux proxy computer, add the TimeOut_ACCEPT additional setting as shown in the following table.
    Property
    Value
    Name
    TimeOut_ACCEPT
    Category
    FileSystemAgent
    Type
    INTEGER
    Value
    100
Configuring Backup Operations to Set Backup Time Attribute
By default, the Commvault software does not set the Backup Time attribute of a file unlike the OpenVMS native BACKUP command. You can configure subclients to set the Backup Time attribute for all files and folders in the subclient content.
  1. From the CommCell Browser, expand Client Computers > client > Proxy Client File System > BackupSet.
  3. On the Content tab, select the Set backup date attribute check box.
  4. Click OK.
Filtering Files from a Backup
Follow the steps given below to configure filters on a subclient:
  2. Right-click the <Subclient> in the right pane and then click Properties.
  3. Click the Filters tab.
  4. Click Add under Exclude these files/folders/patterns and type the path to files and folders that you want to exclude, and then click OK.
    You can also enter patterns of files or folders using wild cards. You cannot enter Escape sequence to specify the path or file name.
  5. Click OK.
Once you set the filters, you can also provide exceptions for the filters. The files or folders added to the exception list will be included in the backup operations. For example, if you want to exclude from your backup operation all the files in the /SYS0 directory except the LOG.TXT file. You can add a subclient filter to exclude the /SYS0 directory from being backed up and also provide an exception to allow the LOG.TXT file to be backed up.
  4. Under Except for these files/folders/patterns, click Add.
  5. Type the file, folder, or directory that you want to include in the backups and then click OK.
    filers_exception
Deleting a Filter
  5. Click Delete.
File System Multi-Streaming employs multiple data streams per subclient for backup operations. This enables the subclient's contents to be distributed to all the streams, transmitting them in parallel to the storage media. Hence a subclient whose data is secured using three data streams, utilizes more of the available network resources, and can complete in as little as one third the time that the same data would require using a single stream.
Use the following steps to configure multi-streaming:
    3. Click Advanced.
    3. Click OK.
  7. Click OK.
The ctime and mtime will be applicable only for the volumes which are scanned by the Recursive Scan. When Optimized Scan is used for scanning the volumes, ctime and mtime will not be taken into account.
  1. From the CommCell Browser, navigate to Client Computers| <Client> | Proxy Client File System | <Backup Set>.
  4. Click OK.
    mtime_ctime
Changing the Log Directory
By default, log files on the OpenVMS client are stored in the [.log] subdirectory of the Commvault installation directory (i.e., DKA0:[SIMPANA.log]). You can change the log directory.
Note that any existing log files in the default log directory will not be migrated to the new log directory. The existing log files will be retained in the original directory. The log files in the new directory will only reflect activity since the Commvault services were restarted.
  1. Stop Commvault services on the OpenVMS client.
    1. On the command line, type the following command:
      SHOW SYSTEM/IMAGE/PROCESS=CVOV_LAUNCHD
      Output:
      OpenVMS V8.4 on node SCS21 22-JUN-2016 10:49:09.79 Uptime 29 02:27:56
      Pid Process Name State Pri I/O CPU Page flts Pages
      00011017 CVOV_LAUNCHD HIB 5 13052 0 00:00:01.47 1294 1542 M
      SCS21$DKA0:[SIMPANA.bin]CVOV_LAUNCHD.EXE;1
      Note the SIMPANA.bin directory path.
    2. Using an @ character followed by the directory path displayed in the output, type the following command:
      @SCS21$DKA0:[SIMPANA.bin]CVOV_STOP
  2. Edit the CVOV_CONFIG.DAT file present in the Commvault directory, and add an entry for the new log directory ({logDirectory=DKA0:[SIMPANALOGS]}/) under the IDA section.
    Note: Provide full path to the new log directory path in either OpenVMS style or UNIX style.
    [Base]
    {listenQueue=20}/
    [IDA]
    {PerfCounter=0}/
    [logger]
    {CLIENTRESTORE_MAXLOGFILEBACKUPS=11/
    {CLIENTSCAN_MAXLOGFILESIZE=5$}/
    {DubToConsole=$[0}/
  3. Restart Commvault services on the OpenVMS client.
    1. Using an @ character followed by the directory path displayed in the output in step 1, type the following command:
      @SCS21$DKA0:[SIMPANA.bin]CVOV_START
Configuring Pre and Post-processing for Backups
  • The first line of the script must execute a command that is designed to call in the pre/post program. Ensure that you have included the appropriate command in the first line of the script.
  • To run a script, MYCOMMAND.COM, type the full path in the OpenVMS native format. Browse functionality is currently not available.
    For example:
    @DKA0:[MYDIR.MYSUBDIR]MYCOMMAND.COM;2
  • You must also configure the exit code in the pre/post script by setting the cvstatus variable value and displaying it before the script exits. The cvstatus value is the actual exit code. Any value other than all zeros will be interpreted as failure.
    For example,
    • To return a PASS exit code:
      $ cvstatus="%X00000000"
      $ show symb cvstatus
      $ EXIT 0
    • To return a FAIL exit code:
      $ cvstatus="%X00000005"
      $ EXIT 0
      Avoid use of DEFINE SYS$OUTPUT <filename>' when running scripts on OpenVMS client as it may result in invalid return status to the access node.
  • From the CommCell Browser, navigate to Client Computers | <Client> | Proxy Client File System | <Backup Set>.
  • Right-click the <Subclient> in the right pane, and then click Properties.
  • In the Subclient Properties dialog box, click Advanced.
  • In the Advanced Subclient Properties dialog box, click the Pre/Post Process tab.
  • Depending on the process you want to set up, type the full path to the process and then click OK.
  4. In the Advanced Subclient Properties dialog box, click the Pre/Post Process tab.
  5. Select the Run Post Scan Process for all attempts check box.
  6. Select the Run Post Backup Process for all attempts check box.
  7. Click OK.
    pre_post_fail
Controlling the Ports for IBM i or OpenVMS File System Clients
Use this additional setting to control the range of ports that are assigned to the dynamically created network connection between a proxy server and an IBM i or OpenVMS client. You can use this additional setting when you want to limit the number of ports opened through the firewall for IBM i or OpenVMS clients.
  • To the access node, add the additional setting as shown in the following table.
    For instructions on how to add additional settings from the CommCell Console, see Add or Modify an Additional Setting.
    Property
    Value
    Name
    dynamicPortRange
    Category
    ProxyClients
    Type
    String
    Value
    <start port>-<end port>
    For example, 10000-101050.
Configuring Linux Proxies Running OpenSSH Version 7 or Higher
If your Linux proxy computer is running OpenSSH Version 7 or higher, an additional configuration step is required prior to setting up subclients for running backup operations.
  1. Check the version of OpenSSH running on your Linux proxy computer by running the following command:
       ssh -V
    Output:
       OpenSSH_7.4p1, OpenSSL 1.0.2k-fips 26 Jan 2017
  2. If the version number after "OpenSSH" is 7 or higher, then perform the following steps:
    1. Go to the home directory of the logged-in user that is running the Commvault processes (typically "root"):
         # ps -eaf | fgrep "Base/cvd"
         root 1079 1 0 Sep17 ? 00:01:27 /opt/commvault/Base/cvd
         # cd ~root
    2. Create a folder ".ssh" if it does not already exist, and go to that folder:
         # mkdir .ssh
         # cd .ssh
    3. Edit the file "config", or create a file if it does not already exist, and add the following lines for each OpenVMS client that will be managed through this Linux access node computer:
      Host OpenVMS_client_hostname KexAlgorithms +diffie-hellman-group1-sha1 HostkeyAlgorithms +ssh-dss Ciphers +3des-cbc
      where OpenVMS_client_hostname is the host name of the OpenVMS client as configured on the CommCell Console or the Command Center.
    4. Go to the home directory as in step 2a.
    5. Create a folder named .putty if it does not already exist, and navigate to the location. On the command line, type the following command:
      mkdir .putty
      cd .putty
    6. In the .putty folder, create a sub-folder named sessions if it does not already exist, and navigate to the location. On the command line, type the following command:
      mkdir sessions
      cd sessions
    7. Create the file Default%20Settings if it does not already exist, and add the following text:
      KEX=ecdh,dh-gex-sha1,dh-group14-sha1,dh-group1-sha1,rsa,dsa,WARN
      If the file exists, find the line beginning with KEX= and replace it with the above text.
Option
Related Topics
Change Storage Policies
  5. Click OK.
Refer to Storage Policies.
Renaming BackupSet:
  4. Click OK.
Renaming subclient:
  4. Click OK.
Data Transfer Options
  • You can configure the data transfer options.From the CommCell Browser, navigate to Client Computers | <Client> | File System | Backup Set.
  • Click the Data Transfer Option tab.
  • Select the Throttle Network Bandwidth check box, and set the required bandwidth.
  • Click OK.
View Data Paths
  5. Click Data Paths.
Configure Activity Control
  4. Click OK.
Refer to Activity Control.
Configure User Security
  5. Click OK.
Refer to Data Encryption.
CommCell Configuration Report
  2. Click Configuration.
  3. Click Run.
Deleting an Agent
Deleting a Backup Set
Deleting a Subclient
