The following requirements are for the Advanced Indexing Pack.
Operating System
- Windows Server 2016 Editions
Processor
All Windows-compatible processors are supported
Hardware Specifications
The software installation requires 20 GB of temp space on the drive where the temp directory resides.
Hard Drive
1 GB minimum of hard disk space for installing the software.
To calculate the disk space requirements for the job results directory, see Job Results Directory Disk Space Calculation.
500 MB of free disk space is required for log directory.
Indexing Requirements
The following tables contain the recommended system requirements for deploying indexing solutions for file data on a single server.
Indexing File Metadata Only
Large |
Medium |
Small |
Objects per node (estimated) |
500 million |
250 million |
125 million |
Source data size per node |
500 TB |
250 TB |
125 TB |
CPU or vCPU |
16 cores |
8 cores |
4 cores |
RAM |
32 GB |
16 GB |
8 GB |
Disk space (SSD class disk recommended) |
500 GB |
250 GB |
125 GB |
Entity Extraction for Files
Large |
Medium |
Small |
60 million |
30 million |
15 million |
20 TB |
10 TB |
5 TB |
CPU or vCPU |
32 cores |
16 cores |
8 cores |
RAM |
64 GB |
32 GB |
16 GB |
20 per cent of source data (up to 4 TB) |
10 per cent of source data (up to 2 TB) |
5 per cent of source data (up to 1 TB) |
Content Indexing from Source
Large |
Medium |
Small |
60 million |
30 million |
15 million |
20 TB |
10 TB |
5 TB |
CPU or vCPU |
32 cores |
16 cores |
8 cores |
RAM |
64 GB |
32 GB |
16 GB |
Disk space |
Content Indexing Files from Backup
Large |
Medium |
Small |
30 million |
15 million |
7.5 million |
20 TB |
10 TB |
5 TB |
CPU or vCPU |
32 cores |
16 cores |
8 cores |
RAM |
64 GB |
32 GB |
16 GB |
Disk space |
30 per cent of source data (up to 6 TB) |
15 per cent of source data (up to 3 TB) |
7.5 per cent of source data (up to 1.5 TB) |
To get higher scalability for content indexing files from backups, you can turn off the generate previews option on the Search Engine node. When generate previews is off, each search node can accommodate approximately twice the number of objects per node. For example, in a large enterprise, this would be approximately 40 TB of source data (about 60 million objects), and the required disk space is 15% of source data (up to 6 TB).
Miscellaneous
Internet Information Services
To install this software, Microsoft Internet Information Services (IIS) must be enabled on the computer and meet the following requirements:
Internet Information Services Manager version 10.0 (on Windows 2016 only)
Internet Information Services Manager version 8.0 or 8.5 (on Windows 2012 only)
.NET Core
.NET Core 8.0.11 is required and is automatically installed.
Microsoft Visual C++
The following Redistributable Packages are installed automatically. Multiple versions of the package can be installed on the same computer.
Microsoft Visual C++ 2010 Redistributable Package
Microsoft Visual C++ 2013 Redistributable Package
DISCLAIMER
