Verify that your environment meets the system requirements for the AIX file system.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Data protection on Logical Partitioning (LPAR) and Workload Partitioning (WPAR) is supported.
Operating system |
Processor architecture |
AIX 7.3 64-bit |
PowerPC |
AIX 7.2 64-bit |
PowerPC |
AIX 7.1 64-bit |
PowerPC |
AIX 6.1 TL 02 SP00 or higher, 64-bit |
PowerPC |
Hard Drive
Component |
Space required |
Software |
1 GB |
Job results folder |
To calculate the space required for the job results folder, see Job Results Directory Disk Space Calculation. |
Log folder |
500 MB |
File System
Enhanced Journal File System (JFS2)
General Parallel File System (GPFS)
Journal File System (JFS)
Oracle ASM Cluster File System (Oracle ACFS)
VERITAS File System (VxFS)
Volume Managers
Veritas Volume Manager (VxVM) 5.0 or higher
Logical Volume Manager (LVM)
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Memory (RAM)
2 GB or more
An additional 1.5 GB for every 500,000 folders in the backup data
IBM Fileset Dependency
Verify that the devices.common.IBM.fc.hba-api fileset exists on the AIX computer.
Schedule Jobs Using a Client Computer's Time Zone
The client computer has to be in one of the standard time zones recognized by the CommServe server. Otherwise, the CommServe server is not updated with the client computer's time zone and the jobs scheduled using the client computer's time zone might not run.
DISCLAIMER
