DB2: System Requirements
Verify that your environment meets the system requirements for DB2.
DB2 Database 12.1 64-Bit (requires Commvault version 11.36.63 or higher)
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
AIX
Operating system
Processor architecture
AIX 7.3 64-bit
PowerPC
Linux
Operating system
Red Hat Enterprise Linux 9.x
Before you install the Commvault software, you must manually install the libxcrypt.x86_64 and libnsl.x86_64 packages on the computer.
x64
SUSE Linux Enterprise Server (SLES) 15
For SLES, verify that the system is using the libstdc++ version - 13.2.1+git8285-150000.1.9.1.
x64
Ubuntu 22.04
x64
Windows
Operating system
Microsoft Windows Server 2022 Editions
All Windows-compatible processors are supported
DB2 Database 11.5/11.1 64-Bit
AIX
Data protection on Logical Partitioning (LPAR) and Workload Partitioning (WPAR) is supported.
Operating system
AIX 7.3 64-bit
PowerPC
Linux
Important
  • If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
  • On Linux, if you installed libstdc++.so.6, you must also install the compat-stdlibc++ rpm that contains libstdc++.so.5.
Operating system
NeoKylin Linux 6.5
x64
x64
Red Hat Enterprise Linux 8.x
x64
Red Hat Enterprise Linux 7.x
  • x64
  • PowerPC (big endian or little endian)
  • Compatible processors
Red Hat Enterprise Linux/CentOS 7.x with glibc 2.17.x or a more recent version
x64
SuSE Linux 15 (Initial Release/SP1 and later SPs) with glibc 2.26.x and higher
x64
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) with glibc 2.19.x
x64
SuSE Linux 12 SP1 Enterprise Server
  • PowerPC
  • PowerPC (little endian)
SuSE Linux 11 (Initial Release/SP1 and later SPs) with glibc 2.9.x and higher
x64
Ubuntu 22.04
  • x64
Important
SuSE Linux 15 (Initial Release/SP1 and later SPs) with glibc 2.26.x is only supported by DB2 Database version 11.5.
Solaris
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating System
Solaris 11.x
Ultra5 or higher recommended
Z-Linux
Operating System
s390x 64-bit
s390x 64-bit
SuSE Linux 12.x Enterprise Server
s390x 64-bit
SuSE Linux Enterprise Server 15.5
s390x 64-bit
Windows
Operating system
Windows Server 2019 Editions
Windows Server 2016 Editions
DB2 Universal Database 10.5, 10.1, 9.7 64-Bit
AIX
Operating system
AIX 7.3 64-bit
PowerPC
HP-UX
Operating system
HP-UX 11i v3 (11.31)
Itanium
HP-UX 11i v1 (11.23)
x64
Linux
Important
Operating system
NeoKylin Linux 6.5
x64
  • x64
Supported only on DB2 versions 10.5, 10.1, and 9.7.
x64
x64
x64
Z-Linux
Operating system
s390x 64-bit
s390x 64-bit
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) Enterprise Server
s390x 64-bit
SuSE Linux 15.5 (Initial Release/SP1/SP2/SP3/SP4/SP5) Enterprise Server
s390x 64-bit
Solaris
Operating system
Solaris 11.x
Solaris 10 Update 6 or equivalent
UltraSPARC-II or more recent recommended
Windows
Operating system
Operating system
DB2 Universal Database 10.5, 10.1 Express Server Edition
Linux
Important
Operating system
x64
x64
x64
SuSE Linux 11 Enterprise Server with libstdc++ version 4.2.4 or above
PowerPC
Windows
Operating system
DB2 Universal Database 9.7 32-Bit
Linux
Important
Operating system
  • x86
PowerPC
Hard Drive
AIX
Component
Space required
Software
3 GB
Job results folder
256 MB
Log folder
256 MB
Linux
Component
Space required
Software
2 GB
Job results folder
256 MB
Log folder
256 MB
Windows
Component
Space required
Software
1 GB
Job results folder
256 MB
Log folder
256 MB
Memory (RAM)
2 GB or more
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Software That Is Automatically Installed
.NET Framework
On most versions of Windows, the .NET Framework 4.7 is automatically installed.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Microsoft Windows 10 and Windows Server 2016, because these versions have the Universal C Runtime already installed.
  • KB2919355
  • KB2939087
  • KB2975061
  • KB2999226
DISCLAIMER
