Review the suggested hardware specifications for MediaAgents to host the deduplicated data. These specifications can be used for setting up partitioned deduplication databases (DDBs) in any of configurations mentioned under the Scaling and Resiliency section.
For more details about the supported platforms, see Building Block Guide - Deduplication System Requirements.
Important
The following hardware requirements are applicable for MediaAgents with deduplication. The requirements do not apply to tape libraries or MediaAgents without deduplication or in setups where third party deduplication applications are used.
In this page, for ease of use, the terms node and MediaAgents are used interchangeably.
The suggested workloads are not software limitations, rather design guidelines for sizing under specific conditions.
The TB values are base-2.
The index cache disk recommendation is for unstructured data types like files, VMs and granular messages. Structured data types like application, databases and so on need significantly less index cache. The recommendations given are per MediaAgent.
The hardware specifications are listed for the most common configurations. You can add as many MediaAgents as required depending on the storage capacity.
After moving a mount path to a new MediaAgent, any other mount paths within the same library must be manually shared with the new MediaAgent.
Capacity
Use the following table to calculate the storage requirements.
Please contact your software vendor for assistance with more advanced design cases.
Back-end Size for Disk Storage
Extra large |
Extra large |
Large |
Large |
Medium |
Medium |
Small |
Extra small |
Grid 9 10 |
1 SSD disk per node |
2 SSD disks per node |
1 Node |
Up to 250 TB |
Up to 500 TB |
Up to 150 TB |
Up to 300 TB |
Up to 75 TB |
Up to 150 TB |
Up to 50 TB |
Up to 25 TB |
2 Node |
Up to 500 TB |
Up to 1000 TB |
Up to 300 TB |
Up to 600 TB |
Up to 150 TB |
Up to 300 TB |
Up to 100 TB |
Up to 50 TB |
3 Node |
Up to 750 TB |
Up to 1500 TB |
Up to 450 TB |
Up to 900 TB |
Up to 225 TB |
Up to 450 TB |
4 Node |
Up to 1000 TB |
Up to 2000 TB |
Up to 600 TB |
Up to 1200 TB |
Up to 300 TB |
Up to 600 TB |
Back-end Size for Cloud Storage
Extra large |
Extra large |
Large |
Large |
Medium |
Medium |
Small |
Extra small |
Grid 8 9 10 |
1 Node |
Up to 500 TB |
Up to 1000 TB |
Up to 300 TB |
Up to 600 TB |
Up to 150 TB |
Up to 300 TB |
Up to 100 TB |
Up to 50 TB |
2 Node |
Up to 1000 TB |
Up to 2000 TB |
Up to 600 TB |
Up to 1200 TB |
Up to 300 TB |
Up to 600 TB |
Up to 200 TB |
Up to 100 TB |
3 Node |
Up to 1500 TB |
Up to 3000 TB |
Up to 900 TB |
Up to 1800 TB |
Up to 450 TB |
Up to 900 TB |
4 Node |
Up to 2000 TB |
Up to 4000 TB |
Up to 1200 TB |
Up to 2400 TB |
Up to 600 TB |
Up to 1200 TB |
Parallel Data Stream Transfers
Grid |
Extra large |
Large |
Medium |
Small |
Extra small |
1 Node |
100 |
100 |
75 |
50 |
25 |
2 Node |
200 |
200 |
150 |
100 |
50 |
3 Node |
300 |
300 |
225 |
4 Node |
400 |
400 |
300 |
CPU/RAM
Components |
Extra large |
Large |
Medium |
Small |
Extra small |
CPU/RAM |
16 CPU cores, 128 GB RAM (or 16 vCPUs/128 GB) |
12 CPU cores, 64 GB RAM (or 12 vCPUs/64 GB) |
8 CPU cores, 32 GB RAM (or 8 vCPUs/32 GB) |
4 CPU cores, 24 GB RAM (or 4 vCPUs/24 GB) |
2 CPU cores, 16 GB RAM (or 2 vCPUs/16 GB) |
Disk Layout
Components |
Extra large |
Large |
Medium |
Small |
Extra small |
OS or Software Disk |
400 GB SSD class disk |
400 GB usable SSD class disk |
400 GB usable disk |
300 GB usable disk |
200 GB usable disk |
DDB Disk |
2 TB SSD Class Disk1,2 2 GB Controller Cache Memory7 For Linux, the DDB volume must be configured by using the Logical Volume Management (LVM) package.6 See Building Block Guide - Deduplication Database |
1.2 TB SSD Class Disk1,2 2 GB Controller Cache Memory7 For Linux, the DDB volume must be configured by using the Logical Volume Management (LVM) package.6 See Building Block Guide - Deduplication Database |
600 GB SSD Class Disk 1,2 2 GB Controller Cache Memory7 For Linux, the DDB volume must be configured by using the Logical Volume Management (LVM) package.6 See Building Block Guide - Deduplication Database |
400 GB SSD Class Disk or SATA Interface2 For Linux, the DDB volume must be configured by using the Logical Volume Management (LVM) package.6 See, Building Block Guide - Deduplication Database. |
200 GB SSD Class Disk or SATA Interface2 For Linux, the DDB volume must be configured by using the Logical Volume Management (LVM) package.6 See, Building Block Guide - Deduplication Database. |
Supported Number of DDB Disks |
Up to 2 |
Up to 2 |
Up to 2 |
Up to 1 |
Up to 1 |
Index Cache Disk3, 4 |
2 TB SSD Class Disk1 |
1 TB SSD Class Disk1 |
400 GB SSD Class Disk8 |
Deploying MediaAgent in Cloud/Virtual Environments
Installing a MediaAgent in a cloud or virtual environment is supported. For more details about AWS and Azure sizing, see the following:
Configuration
After determining the number of MediaAgents for your setup by using the back-end-size table, you must create a network storage pool using these MediaAgents. For more information about creating a network storage pool, see Network Storage Pool.
If you have multiple sites, then create a network storage pool per site for cross-site replication. For information about cross-site replication, see Cross-site Replication.
You can scale up or scale down your setup by adding or deleting the number of MediaAgents required to process your data. The following factors affect the number of MediaAgents that are required in your setup:
The back-end size of the data. For example: Each 2TB DDB disk holds up to 250 TB for disk and 500 TB for cloud extra large MediaAgent.
Resiliency for backups allows for node failover by automatically redirecting the backup process to another node if 1 node is temporarily unavailable.
You can use these scaling and resiliency factors to set up partitioned deduplication databases in any of following configurations:
Partition mode: In this mode only 1 storage pool is configured using all the MediaAgents in a grid with 1, 2, 4, or 6 partitions. Use 6 partition DDB for 6 or more nodes.
Partition extended mode: In this mode the MediaAgents host partitions from multiple storage pools (up to 20 storage pools per grid). Each storage pool can be configured with 1, 2, 4, or 6 partitions.
You can use the partition extended mode in the following scenarios:
When you want the primary copy of the data on the disk and the secondary copy on the cloud. In this case, create 1 disk storage pool and 1 cloud storage pool using the same MediaAgents.
In case of multi-tenancy, where the total back-end size of multiple tenants together is within the limit of the grid. In this case, to segregate data for each tenant you can configure the partition in extended mode by creating a separate storage pool for each tenant using the same MediaAgents.
The software scales the DDBs horizontally. For more information, see Deduplication Building Block Guide.
Footnotes
SSD class disk indicates internal dedicated endurance value drives. Use MLCs (Multi-Level Cells) class or better SSDs. It is recommended to use the mixed use enterprise class SSDs.
Recommend dedicated RAID 1 or RAID 10 group.
To improve the indexing performance, store your index data on a solid-state drive (SSD). The following agents and cases require the best possible indexing performance:
Exchange Mailbox Agent
Virtual Server Agents
NAS filers running NDMP backups
Backing up large file servers
SharePoint Agents
The index cache directory must be on a local drive. Network drives are not supported.
Use dedicated volume for Index Cache Disk and DDB Disk.
If RAID cache is shared by other components, then 2GB controller cache might not be sufficient.
Spinning disk can be used only for small and extra small configurations.
Higher deduplication block size is used to calculate the back-end size for the cloud storage. When you use cloud storage for secondary copy where the source is disk storage, refer to Back-end Size for Disk Storage for storage requirements.
Back-end storage size (BET) requirements approximately range from 1.0–1.6 times of the front-end data size (FET). This factor will vary directly in proportion with the amount of retention required and the amount of daily change rate for the front-end data. For example, if the data is retained for lower number of days, then it reduces the predicted amount of back-end storage requirement. Whereas, if the extended retention rules are applied to a larger portion of the managed data, then it can increase the back-end storage consumption. The FET estimate can be used in the storage policy design to help size the appropriate resources to support the use-case.
The following are examples of commonly used settings for the backup retention.
Example 1:
80% VM/File data
20% Database data
Daily change rate 2%
Compression rate 50%
Daily backups are retained for 30 days
Factoring in these parameters, the back-end storage size requirements can range from 1.0 - 1.2 times the front-end data size.
Example 2:
80% VM/File data
20% Database data
8 weekly backups are retained for 1 year
9 monthly backups are retained for 1 year
1 yearly backup is retained
Factoring in these parameters, the back-end storage size requirements can range from 1.4 - 1.6 times the front-end data size.
As specified in the Scaling and Resiliency section above, you can add as many nodes as required based on size. Take sizes from single node mentioned in table to compute size for 6 or more nodes.
